Do Japanese authorities need to cool before dismantle
  • Thread starter cloa513
  • Tags
    Cool
In summary, AREVA plans to set up a water decontamination process for the Fukushima site in order to remove radioactive material from the site.
cloa513
36
I am thinking why not use mobile cranes to slowly prepare to remove fuel rods (vision from UAV or distant helicopters or balloons) (cutting using fibre lasers) and then remove and contain fuel rods. They already have a concrete truck reaching 44 metres to deliver water and the world longest reach crane is 100 m so the lengths to reach are within current technology. Most of crane's actions are mechanical so radiation is not a big issue and operator would be out of line of sight.
Is it just linear thinking on the nuclear authorities/industry or is absolutely necessary to get cooling to work permanently before considering dismantling?
Yes - for assemblies or collection of fuel rods. They are waiting to place the assemblies and collection of rods in more secure containment. The heat generation and radioactivity must be allowed to decay in order for current systems to be used for storage.
The other concern is decontamination of the water used to cool the spent fuel and fuel in the reactor. The radionuclides will have to be filtered and collected, and packaged securely for final disposal.
Thank you for your reply. No reason that accessing the top of the plant should in any way (except sometimes less direct water flows for short periods) affect their other activities whether it be water management or cooling systems. The fuel rods may be very hot but for high temperature steels e.g. 1000 C is no big deal for short periods (specialty steels) and steel may be affected by the radiation but hardly likely over short periods. The fuel rods only need to put and contained in short term steel vessels long enough for more permanent vessels to made available.
Actually AREVA has a plan to process the radioactive water.
From AREVA's website - AREVA to set up a water decontamination process for the Fukushima site
http://www.areva.com/EN/news-8856/a...amination-process-for-the-fukushima-site.html
They need to decontaminate the cores and SFP to the extent possible, then the remove whatever fuel is intact, then remove the debris, then disassemble the primary systems, then disassemble the containment and secondary sides.
I cannot provide a definitive answer to this question as it ultimately depends on a variety of factors, including the current state of the nuclear reactor, the safety protocols in place, and the expertise and resources of the Japanese authorities. However, I can offer some insights and considerations.
Firstly, it is important to note that the Fukushima Daiichi nuclear disaster is a complex and unprecedented situation, and there is no one-size-fits-all solution. The decision to cool the reactor before dismantling may be influenced by a number of factors, including the potential risks and consequences of dismantling without proper cooling, the availability of resources and technology, and the expertise and experience of the authorities involved.
Using mobile cranes and remote technology, such as UAVs or distant helicopters, may be a feasible option for dismantling the reactor. However, it is important to carefully assess the potential risks and challenges associated with this approach. For example, the use of fibre lasers for cutting may pose a potential fire hazard if used in close proximity to the nuclear reactor. Additionally, the operation of cranes and other equipment in a highly contaminated environment may require specialized training and safety measures to minimize the risk of radiation exposure.
It is also worth considering the long-term implications of dismantling the reactor without properly cooling it. While using cranes and remote technology may seem like a more efficient approach, it is important to ensure that the dismantling process does not compromise the safety and stability of the reactor and surrounding environment. Any hasty decisions or shortcuts in the dismantling process could potentially lead to further risks and complications in the future.
In conclusion, while using mobile cranes and remote technology may be a viable option for dismantling the Fukushima Daiichi nuclear reactor, it is crucial that the authorities carefully assess the risks and challenges involved and prioritize the safety and stability of the reactor and surrounding environment. Ultimately, the decision to cool before dismantling should be made with careful consideration and consultation with experts in the field.
1. What is the purpose of cooling before dismantling nuclear reactors in Japan?
The cooling process is necessary to prevent a potential nuclear meltdown. When a nuclear reactor is shut down, there is still residual heat that needs to be removed to prevent the fuel rods from overheating and potentially releasing harmful radiation.
2. How long does the cooling process typically take?
The cooling process can take anywhere from several days to several weeks, depending on the size and type of the reactor. It is important for authorities to carefully monitor and control the cooling process to ensure the safety of the surrounding area.
3. Are there any risks associated with cooling before dismantling?
While there are risks involved in any nuclear operation, the cooling process itself is not considered to be a high-risk activity. However, proper precautions and safety measures must be in place to prevent accidents or malfunctions during the cooling process.
4. What happens to the nuclear waste during the cooling process?
The nuclear waste, which includes spent fuel rods, is typically stored in a cooling pool while the reactor is being cooled. Once the reactor has been fully cooled, the waste can be safely removed and stored in a more permanent location.
5. Are there other methods of dismantling nuclear reactors besides cooling?
Yes, there are other methods of dismantling nuclear reactors, such as using robotic technology or remote-controlled equipment. However, cooling is still an essential step in the dismantling process to ensure the safety of workers and the surrounding environment.
  • General Discussion
