Ultraviolette Catastrophy -Intensity causes melting of objects?
  • Thread starter christian0710
  • Tags
    Melting
In summary: The ultra-violet catastrophe is a failure of classical electromagnetic theory and the equipartition theorem.
christian0710
409
Hi,
Is it correctly understood that it's the intensity of light that causes melting or heating of objects and not frequency or vice versa? I'm trying to understand the ultraviolette catastrophe (what the problem was) and according the the equation for intensity (given below) frequency increases exponentially, when intensity increases, so is this the poblem scientists were facing: if a black body radiates light at high intensity it would produce a frequency that was high enough to melt objects and as the intensity increased the frequency would go to inifnity?
I = (2*f*Kbb*T)/c^2
Science news on Phys.org
No.
Frequency of light is not what melts objects. Objects melt roughly due to being high enough in temperature such that the kinetic energy of the molecules of the solid can overcome the inter-molecular forces holding the object in its solid state.
The ultraviolet catastrophe has nothing to do with melting objects. It's that the prediction of black body radiation intensity by Rayleigh and Jeans predicts an infinite total intensity due to the intensity frequency relationship diverging as the frequency grows. It was an experimentally known fact that this is obviously wrong.
christian0710 said:
Hi,
I = (2*f*Kbb*T)/c^2
The ultraviolet catastrophe results from classical electromagnetic theory and from the equipartition theorem of the classical kinetic theory (statistical mechanics). According to classical EM theory, the number of vibrational modes (analagous to classical degrees of freedom) of an EM wave in a black-body cavity resonator should be proportional to the frequency^2. According to the equipartition theorem, all modes should have the equal energy. So the rate at which energy is radiated by the black body should increase rapidly with frequency (ie in proportion to the number of vibrational modes which is proportional to the square of the frequency). Since this is not observed, it is apparent that classical physics is not adequate to explain black-body radiation.
My sense is that the ultra-violet catastrophe is more a failure of the equipartition theorem than of classical EM theory.
AM
Related to Ultraviolette Catastrophy -Intensity causes melting of objects?
1. What is the Ultraviolette Catastrophy?
The Ultraviolette Catastrophy, also known as the Ultraviolet Catastrophe, is a phenomenon in which increased intensity of ultraviolet radiation causes objects to melt.
2. How does intensity cause melting of objects in the Ultraviolette Catastrophy?
The intensity of ultraviolet radiation refers to the amount of energy being emitted. As the intensity increases, the energy absorbed by an object also increases. This excess energy causes the atoms in the object to vibrate more rapidly, leading to a rise in temperature and ultimately causing the object to melt.
3. What causes the Ultraviolette Catastrophy?
The Ultraviolette Catastrophy is caused by the relationship between an object's temperature and the intensity of ultraviolet radiation. As an object's temperature increases, it emits more radiation. This radiation can then interact with other objects, causing a chain reaction of energy exchange that can result in melting.
4. Is the Ultraviolette Catastrophy a real phenomenon?
Yes, the Ultraviolette Catastrophy is a well-documented and observed phenomenon in physics. It was first described by the German physicist Max Planck in the early 1900s and has since been confirmed through numerous experiments and observations.
5. Can the Ultraviolette Catastrophy occur in everyday life?
While the Ultraviolette Catastrophy is a real phenomenon, it typically only occurs at very high levels of intensity, such as in extreme laboratory conditions or in outer space. In everyday life, the intensity of ultraviolet radiation is not typically high enough to cause objects to melt.
  • Quantum Physics
19K
