Electric Field Induced by Varying Magnetic Field
In summary, a uniform magnetic field normal to the plane of the screen with varying magnitude will induce an electric field with concentric circular field lines centered around a point P on the screen. This direction of the electric field is tangent to the circle. This also occurs for a point Q, resulting in two directions of electric field at all points. If we place a stationary electron in this varying magnetic field without any circuit, it will move along a circular path. This is due to Faraday's law, which states that a changing magnetic field produces an electric field. This electric field can influence free charges such as electrons, even without a conducting ring or sheet. However, the characteristics of the magnetic field and its geometry, as well as the location of
kini.Amith
83
I am a high school student, so forgive me if my question appears stupid.
Consider a uniform magnetic field normal to the plane of the screen with varying magnitude. consider a point P on the screen in the magnetic field.the varying magnetic field will induce an electric field, with the field lines in the form of concentric circles centred around p. direction of field tangent to the circle .consider another point Q other than p. we can also think of concentric electric electric field lines around Q.
The circles around Q and those around P will intersect giving 2 directions of electric field at all points. if we think of more points other than P and Q, there will be electric field lines flying everywhere. So what will happen if i simply place a stationary electron in this varying mag field, without any circuit?
Thank you for reading.
The electromotive force induced about each magnetic flux line drives a current that acts to shield the flux from the interior of the conductor. This is called an eddy current. By symmetry, as you point out, there is no net current in the region of uniform field. An intuitive picture of this is that the circular current around one flux line is canceled by those around neighboring flux lines. Here's the physical picture: ooo (if the sense is clockwise in each circle, then current to left and right of the center sums to zero. Similarly for currents above and below.) An electron at the center feels no force.
On the other hand, if the conducting sheet is large and the uniform field localized and smaller than the sheet, then at the edges where the field intensity falls away, the cancellation does not occur. Eddy currents flow round the outside of the region where the uniform field intersects the sheet. Similarly, if the field is uniform and the sheet finite and small, eddy currents will flow around the boundary of the sheet.
But that is the case inside a conducting sheet.
according to Fundamental of Physics by Resnick, Halliday and Walker,
" A changing magnetic field produces an electric field. The striking feature of this statement is that the electric field is induced even if there is no conducting ring or sheet."
So does that mean that if i simply place a stationary electron in free space in the changing magnetic field, it will move along a circular path?
Yes, that is correct. Mathematically, Faraday's law gives the electromotive force around a closed line path as
[tex]\varepsilon=\oint\vec{E}\cdot d\vec{l}=-\frac{d}{dt}\int_S \vec{B}\cdot d\vec{A}[/tex]
where the line integral on the left is taken about the boundary to the surface S and where dA is the normal to the differential of surface area. The right-hand integral gives the magnetic flux enclosed by the boundary.
In the absence of a unique physical path such as a wire loop, you must consider the sum of all possible imaginary closed paths just as in the case of the conductive sheet that I already discussed. A test charge in the center of a time-varying but uniform field again feels no force.
If the field is contained within a finite volume, on the other hand, let's say a cylindrical region between two pole faces of a C shaped electromagnet, then a test charge located radially outside the cylindrical region will experience an electric force. We can draw a closed path through the test charge that fully surrounds the field, therefore generating an emf according to Faraday's law. All other loops through the charge surround field-free regions and have no E field or emf, so there is no cancellation. The charge sees a net E field and feels a force.
that's interesting. Thanks.
You have asked an excellent question extremely fundamental to the understanding of the critical details of magnetic induction. Resnick etc, is both right and wrong in their statement. A changing magnetic field does NOT produce an electric field. A changing current does that. The current ALSO produces a changing magnetic field related to the Electric field (both have the same source). But the correct part is that the changing current produces an E field in the space. IF the E field is located inside a conductor then a large current can easily be induced. If there is no conductor the E fields remains and can indeed influence free charges such as electrons.
The first thing you have to ask is what are the characteristics of the magnetic field, which is to ask in another sense what is the geometry of the source current? Just for drill let us take a long solenoid as our source current. Since our induced E field can ALSO be found from a time-changing Magnetic Vector Potential we note that the magnetic potential A inside the solenoid can be found to be equal to:
A=unIr/2L Where u is mu naught, n is the number of turns, L is the solenoid length, I is the current and r is the distance form the axis of the solenoid. The Vector A is in the azimuthal or theta direction.
For this reason one finds that the induced E field inside the solenoid E = - dI/dt (unr/2L) also in the azimuthal direction.
Ok. Now look at an electron placed in the exact center of the solenoid. At that point r = 0. And thus E = 0. And thus the electron will experience no force from the induction. Note that as the distance from the center, r, is increased so does the accelerating E field. The E field being in the theta direction is always tangential to a circular orbit about the center of the solenoid. The further out you are the greater the acceleration. F = qE = ma.
It is interesting to note that if one goes OUTSIDE the solenoid where the magnetic field is ZERO, the acceleration persists even though there is NO magnetic field present at the electron. Which is something of a hint that it is not the magnetic field creating the E field accelerating the electron!
For a really good time, I suggest doing a search on the subject "betatron"!
I'd like to point out that bjacoby's adherence to the belief that magnetic fields have no independent existence from charge is his own theory, not consistent with accepted classical physics as born out by the generally accepted notion of propagating electromagnetic fields. The rest of it seem similarly constructed
This,
”It is interesting to note that if one goes OUTSIDE the solenoid where the magnetic field is ZERO, the acceleration persists even though there is NO magnetic field present at the electron. Which is something of a hint that it is not the magnetic field creating the E field accelerating the electron!”
is just plain wrong.
I suggest you ask more questions and pontificate less, bjocoby, or the powers-that-be will ban you from this forum. Personally, I find this category of misinformation extremely annoying.
Every once in a great while here, kini.Amith, someone who is trying to learn such as yourself, asks a gem of a question. Thanks! Yours is one of them. A 'gem' is something I think I should know the answer to, but am shocked that I don't.
How does a point charge behave in a uniform magnetic field changing with time?
I will use Maxwell's equation of induction in differential form.
We cannot use the integral form of inductance because it only tells us about the total path integral of the electric field over a loop, rather than at the coordinate of the particle.
In differential form,
[tex]\nabla \cdot E = \frac{\partial B}{\partial t} \ .[/tex]
Make it a uniform magnetic field Bz along the z-axis for convenience.
[tex]\frac{\partial E_x}{\partial y} - \frac{\partial E_y}{\partial x} = \frac{\partial B}{\partial t} \ .[/tex]
This tells us that the electric field is directed somewhere within the XY-plane, but not in what direction.
The uniformity of the magnetic field tells us that there is no preferred direction in the XY-plane.
Are the classical Maxwell equations complete or ambiguous in the specification of the electric and magnetic field vectors at spacetime coordinates?
Is the problem set-up erronious; are uniform time varying magnetic fields prelcuded on basis I'm not aware of?
This is a pretty advanced question for a high school student. I can answer it, but I am not sure if it will be a comprehensible answer, so I apologize in advance if I cause more confusion than I clear up.
For most problems in electromagnetism, it is preferable to work in terms of the vector and scalar potentials, rather than in terms of the fields themselves: http://en.wikipedia.org/wiki/Mathem...lectromagnetic_field#Potential_field_approach
So for this problem, in units where c=1, we can specify the vector potential as
[tex]\mathbf{A}=\left( -y \, cos(\omega t),x \, cos(\omega t),0 \right)[/tex]
which yields the desired B-field:
[tex]\mathbf{B}=\nabla \times \mathbf{A} = \left( 0,0,2 \, cos(\omega t) \right)[/tex]
Everything else is free, so let us choose the simplest possible scalar potential
[tex]V=0[/tex]
which yields the following E-field:
[tex]\mathbf{E} = \nabla V - \frac{\partial \mathbf{A}}{\partial t}=\left( -y \omega \, sin(\omega t),x \omega \, sin(\omega t),0 \right)[/tex]
Furthermore, we can easily calculate the charge and current densities:
[tex]\rho = -\nabla^2 V - \frac{\partial}{\partial t} \left ( \nabla \cdot \mathbf A \right ) = 0[/tex]
[tex] \mathbf J = -\left ( \nabla^2 \mathbf A - \frac{\partial^2 \mathbf A}{\partial t^2} \right ) + \nabla \left ( \nabla \cdot \mathbf A + \frac{\partial V}{\partial t} \right ) = \left( y \omega^2 \, cos(\omega t),-x \omega^2 \, cos(\omega t),0 \right)[/tex]
And we can check back to verify that the obtained fields and densities satisfy Maxwell's equations:
[tex]\nabla \cdot \mathbf{E} = 0 = \rho[/tex]
[tex]\nabla \cdot \mathbf{B} = 0[/tex]
[tex]\nabla \times \mathbf{E} = \left( 0,0,2 \omega \, sin(\omega t) \right) = -\frac {\partial \mathbf{B}}{\partial t}[/tex]
[tex]\nabla \times \mathbf{B} = 0 = \left( y \omega^2 \, cos(\omega t), -x \omega^2 \, cos(\omega t), 0\right) + \left( -y \omega^2 \, cos(\omega t), x \omega^2 \, cos(\omega t), 0\right) = \mathbf{J} + \frac{\partial \mathbf{E}}{\partial t}[/tex]
So, the E field lines are not just "flying everywhere", but are quite well defined, and a charge at rest at any given location will be pushed in the direction of the local E field.
This,
I suggest that instead of repeating errors you provide some justification for your dogmatic beliefs! Can you provide proof that magnetic and electric fields create each other in electromagnetic propagation? Please provide it. Do you agree that charges and their motions create both Magnetic and Electric fields? Do you not agree that these fields propagate away from that charge/current in free space at the speed of light? Do you not agree that therefore in Maxwell's equation that says the curl of E = the negative time rate of change of B both E and B are occurring simultaneously being equally retarded from the source? It is widely accepted that E and B are simultaneous in this equation in that time does not appear as a parameter! Do you not agree that magnetic and electric fields in electromagnetic propagation in free space are IN PHASE. And lastly do you not agree with the premise that actions which occur at the same time CANNOT "create" each other?
In addition you are saying that my assertion that there is no magnetic field outside a long solenoid is "just plain wrong", is that not true? So I take it your assertion is that the magnetic field that exists outside the solenoid creates the Induced E field there. Please explain this further. I'd really like to know more about this magnetic field OUTSIDE a long solenoid. Or how the magnetic field INSIDE the solenoid creates an E field "at a distance" outside it? In fact you have explained nothing here, simply going for "proof by assertion". Please explain exactly what you mean so we can all discuss it. It's a physics forum so it's relevant. These are all questions very fundamental to a study of electromagnetics.
Of course if you wish to turn this forum into a religious one with heresy suppressed through censorship, that is your opinion. I on the other hand believe that science is a matter of proof and data rather than opinion and "accepted" dogma. Let us hope that the "powers that be" have more respect for the scientific method than to ban discussions of widely accepted dogma. If I am making some kind of fundamental error here then I'd sure liked to hear about it in detail. The fact that I seem to annoy you is totally irrelevant to a sensible discussion of this issue.
It seems to me that questioning "accepted notions" is how science advances. I'm sure there is a lot of good done here by providing beginners an understanding of textbook principles, but to restrict this forum to being merely a rubber stamp for textbook dogma seems to me to restrict it's potential as a tool for the promotion of science and physics.
bjacoby said:
I suggest that instead of repeating errors you provide some justification for your dogmatic beliefs! Can you provide proof that magnetic and electric fields create each other in electromagnetic propagation? Please provide it. Do you agree that charges and their motions create both Magnetic and Electric fields? [snip]
Post one of your questions or assertions in a thread where it can be addressed.
I think this is an inappropriate representation at this level of the discussion. Of course you can calculate the fields E and B by using retarded potentials, which you can see as "direct" effects of the sources (charges and currents). This is I think what you allude to. In this view, the E and B fields are not "dynamical variables" but just "directly" derived from the sources (charges and currents). Mind you that this is only a particular solution of the electromagnetic field equations, and that we took them to have boundary conditions of "zero at infinity".
But if you consider the E and B fields as the "state variables" of the EM field, and you only allow for local field equations (and hence no "retarded" stuff), then you can't escape that the E-field IS dependent on the change in B-field.
If it is a straight, long, but finite solenoid, then of course there is a magnetic field outside of the solenoid! B-field lines are closed lines, so in order for them to be closed, they have to return on the outside.
For an infinite-length solenoid, that's not the case, and for a torus, either. But in these cases, you don't have your electron accelerating outside of the solenoid either.
So please stop nitpicking in this discussion as if it were a "dogmatic" point. You're on the verge of misinformation here.
DaleSpam, how can it end up with a current if we specify there is none? Perhaps a different choice of vector potential, limited to a first power of time. I would like to point out it still is not unique. If we make a simple example vector potential:
[tex]\vec{A} = xBt\hat{y}[/tex]
then
[tex]\nabla\times \vec{A} = \partial_x A_y \hat{z} = Bt\hat{z}[/tex]
and then
[tex]\vec{E} = -\partial_t \vec{A} = -xB\hat{y}[/tex]
However, A is not unique. What if, for example, we had:
[tex]\vec{A} = -yBt/2\hat{x} + xBt/2\hat{y}[/tex]
then
[tex]\nabla\times \vec{A} = (\partial_x A_y - \partial_y A_x)\hat{z} = Bt\hat{z}[/tex]
But, now you see E would be completely different.
[tex]\vec{E} = yB/2\hat{x} - xB/2\hat{y}[/tex]
Now, imagine a source. An infinite current sheet will produce a uniform magnetic field. But, notice it would not matter if we rotated the current sheet, magnetic field would still be uniform, unless you pass from one side of the sheet to the other where it flips direction. However, now you have a basis for which A to use (the one parallel to sheet). So, it seems you need the boundary conditions, even when B is uniform.
So, back to the origional question. It seems the electric field may not be uniform, depending on the boundary conditions. It is clearly zero at the center of a solenoid, but needs to form parallel to the boundary. So you get concentric circular e-field increasing in magnitude, until you reach the current source. Then outside it forms concentric rings of decreasing strength (this is how transformers work).
(As for infinite solenoids. 1) Classical charged particles are not deflected where the solenoid is constant current. (However, real charged particles undergo a phase change, measurable by self-interference, but where the average probability distribution is unchanged, that has no context withing the classical axioms of this folder .) 2) But the OP is asking about a B field changing over time, in which there are certainly exterior B fields present for an infinite solenoid.)
You're a darned genius Dale. I get it, that there is a constant that is lost upon differrentiating the vector potential so that E of B is not unique, but haven't you specified some specific boundry conditions to arrive at a particular solution?
In this case you've constrained the magnetic potential to zero at the origin. I haven't yet hashed it out: can we arbitrarily move the zero potential anywhere we wish by a gauge transformation of A?
You are correct, the question itself is ill posed in that regard, it did not describe which of many possible current configurations (including no current) and time variations was to be considered.
then
and then
This is an interesting example. You have no currents and no charge (for V=0), but a linearly increasing (in space) E-field leading to a linearly increasing (in time) B field. With sourceless fields it is in some sense a non-physical solution, but such solutions can be valuable in understanding anyway. Here we see that the usual intuition that the E field lines are curving around something is not necessarily the case. Here the E-field is [itex]\mathbf{E}=(0,-B x, 0)[/itex] so again the OP's concern about E-field lines "flying everywhere" does not arise.
then
Yes you would expect different fields since this change of A and V is not a gauge transformation, but the resulting fields do indeed satisfy Maxwell's equations and the E-field is still well-defined. This solution is closer to my original solution, just with a linear time variation rather than a sinusoidal one.
I agree fully.
Implicitly, yes. The boundary conditions were not specified in the problem, so I just picked whatever fell out easiest when I sat down to work it. As kcdodd has shown other choices lead to other equally valid solutions for different sources and boundary conditions.
Yes, but then you would have a non-zero scalar potential resulting in the same fields and currents in the end.
I'm not trying to escape the fact that Maxwell's equation is TRUE. The point I've tried to make is that while it's true (the VALUE of a changing magnetic field can be used to (usually) calculate the VALUE of the induced E field) the error is to assume that the equation implies that one side CAUSES the other. That is the important point. The fact that both sides of the equation happen simultaneously and transluminal action is prohibited proves what I contend.
I agree one can take a "state variable" approach and obtain useful answers, but I don't see where that has any bearing on causality. In fact by ignoring retardation it simply ignores the issue. We've already noted that E and B are related so that is not an issue but what "causes" what is an issue.
As for the field outside of a long solenoid, yes, you make a good point. I had indeed forgotten about the looping fields out there. Of course as you note, if the solenoid is "infinitely long" (which real solenoids can never be) those looping fields would tend to zero.
But the issue is easily addressed as you do by simply proposing a toroidal coil instead. And I assure you that the electron does indeed experience an accelerating E field outside both the theoretically "infinite" solenoid or the torus. Even if the field outside were relatively weak and not truly zero, how could one still explain the fact that the induced E field just inside the coils is nearly equal to the E field just outside the coils?
As for "nitpicking", I simply answered a question using my understanding of the problem. And then I was attacked for being "wrong". I am trying to understand just where in my understanding I have made false statements or false assumptions. So far nobody has provided any except your "state variable" approach which simply removes retardation from the calculations or your statement that an Induced E field does not exist outside a torus or long solenoid which is incorrect.
You have, however, raised a very important point which has to do with boundary conditions and the resolution of such conditions with propagation in source-free space. It's a matter that requires some thought.
On the other hand, I do not understand what being on the "verge of misinformation" means. I mean, if I'm right then theory should support it. If I'm wrong in some matter, then it certainly should be pointed out to me so I will not continue making statements that are not correct. I simply do not see where these arguments I've made are wrong.
Excellent suggestion! It is not my intention to highjack this thread with a different issue, even though the original question was very much related to what produces an E field when a changing magnetic field is present.
bjacoby, I think both your "position", and the "contrary" "position", are both right and wrong in some respects. Haha.
To Phrak's side, you are indeed mistaken here
This,
This is a common misconception because there is no magnetic field, and yet you see an electric field. The fact is, Maxwell's equations are local quantities, but they actually define a global field! You cannot reliably construct the full E and B from a simple, local, view of maxwell equations, because they are simply differential equations. In a sense, you must still "integrate", or "solve", maxwell's equations over all of space (globaly), to get E and B.
As an example, look at a single point charge. The divergence of E only occurs at a single point, and is zero everywhere else. And yet you have E filling all of space.
The same view must is held here. Just because the curl of E is zero outside an infinite solenoid (or toroid), does not mean E is zero. If you use stokes theorem, and integrate around the solenoid, you can see that clearly. If you don't believe it, open up any transformer and see it work! The point is that maxwells equations do not give you a local solution to E, only local differential equation which must be solves somehow.
however, saying a changing B-field does not cause an E field, or rather vice versa, is a trickier subject. Consider the harmonic oscillator:
[tex] \ddot{x} = -\omega^2 x[/tex]
Which side causes which in this case? This equation contains both simultaneous quantities. Your view on causality is, in some sense, subjective. But, we usually take the right side to cause the left side as a matter of our physical common sense (a spring "pulls on me"). And yet, if you where to instead specify an acceleration, I could tell you exactly what x is. The point is, If you say maxwells equations are non-causal, then you have to say all differential equations are non-causal.
This is a common misconception because there is no magnetic field, and yet you see an electric field. The fact is, Maxwell's equations are local quantities, but they actually define a global field! You cannot reliably construct the full E and B from a simple, local, view of Maxwell equations, because they are simply differential equations. In a sense, you must still "integrate", or "solve", Maxwell's equations over all of space (globally), to get E and B.
What you say does have validity to a degree. And since certain (not all) Maxwell's equations are local that means they really aren't causal relations, does it not? If we take the two Maxwell equations that contain the time rate of change of B and the time rate of change of D we find that it follows from this that where there exists a time-variable electric field there also exists a time-variable magnetic field. But neither of these equations indicate causal links between magnetic and electric fields. In fact, because of the simultaneity of E and B they simply cannot "cause each other". Well if that is true then clearly we have two entities that are caused by some common source. The suggestion is that time-variable charges and currents are that source.
But as you note Maxwell's equations must be solved for all space and our conclusion must hold for all fields including EM waves.
Now there is a vector identity that allows any time-variable vector field [regular field meaning goes to zero at infinity] to be represented as :
V = -[tex]\frac{1}{4\pi}[/tex][tex]\int[/tex][tex]\frac{[X]}{r}[/tex]dV'
Where X is
[tex]\nabla^{}[/tex][tex]^{2}[/tex]V -[tex]\frac{1}{c^{2}}[/tex][tex]\frac{\partial^{2}V}{\partial^{2}t^{2}}[/tex] = 0
And we note that X is the equation for EM waves in free (empty) space with V being either E or B. Hence there is a contradiction here as if the integrand is zero then V = 0! But we know V is a wave field and not at all zero. Thus X implies that there can be "sourceless" EM waves while our identity says this cannot be true. The answer is that the integration is over "all space"! and the wave equation only applies to a limited region of space (source-free) It's clear that if V does not equal zero somewhere in space then there must be a region where the wave equation doesn't hold. And of course this region is that which holds (or did hold) the sources that created the waves! and from which the fields are retarded.
And notice one more thing. The first identity says that there can be no wave fields unless X holds. but X can only apply to a limited region of space. Thus is shown that if an EM wave exists there MUST be a region in space where the wave equation does not hold where the sources of the waves are located. Which gives causality to EM waves from that source! Hence in the same way that I have claimed (as Phrak so magnificently put it) that "magnetic fields have no independent existence from charges" it also appears that Electromagentic radiation ALSO has no independent existence from charges as well! Although one can say with assurance that both EM waves and magnetic fields do propagate through charge-free space at the speed of light with no problem.
Thus one can see that certain care must be taken when using the solutions to Maxwell's equations. Inappropriate integrations can lead to conflicting results as above until care is taken to sort things out.
And since we are "sorting things out" I might mention that I have seen a paper which asserts that the magnetic field outside a long solenoid or torus is in fact NOT zero but only zero in the static case. When one has induction, the fields are clearly all time-variable. Which gives rise to a possibility of magnetic fields actually being present where the E field is being generated in the static magnetic-free space. Although this is in fact a point suggestive against my premise. If one looks at HOW the fields are zero outside a long solenoid, one observes that fields from the near portion of the coil are canceled by fields from the farther portion. This gives rise to a number of questions. The most obvious is that the retardation from the near currents are less than from the far currents leading to an incomplete cancellation. Another would be the question if the magnetic fields truly "cancel" meaning result in "no field" or if the two opposing fields remain and only cancel with regard to physical measurements (say you jam a gauss meter there). But on the other hand this doesn't change the fact that E and B are simulataneous and hence cannot "cause each other".
The real question here would be what could possibly be a "model" for magnetic induction. Simply pointing to equations that give the "correct" answer is only a description, not an explanation. How could it be that a changing current creates an E field parallel or anti-parallel to itself retarded at some distance? It can't possibly be the magnetic field that does this. Why? Well, we've sort of dismissed the solenoid argument but there is one we can't dismiss. By Biot-Savart law a magnetic field from a current element varies as the sign of the angle the observation point makes with the current element. Hence this says that the magnetic field DOWN A WIRE, AT THE WIRE, from the current in the wire is zero if the wire is straight and very thin. So this leads us to surmise that straight wires can't have self-inductance which is of course, totally false. So how is an E field created at a distance from a changing current? Well the math says it's done not by [retarded] B but by [retarded] A (which does indeed exist down the wire). So now we then have to look for a model for A. While for many years A has been regarded as little more than a math trick, Feynman has suggested that in the big picture A just may be the more "fundamental" field. It's all "classic" physics but still very interesting stuff!
Please excuse my attempt to write equations. I'm still a hopeless noob at doing that!
Yes, I should have known that; the (phi,A) field is not classically distinguishable from (phi,A)'.
The moral of the story seems to be that neither E nor B are unique functions of the other, but each is a unique function of A. Of course, we're happy to do this very thing: to pick a unique solution for E and B, given a distribution charge and currents.
Thanks kcdodd. I went back and read your post.
Interesting, I am not sure what that integral is, if you can explain its origin. Perhaps it is related to the helmholtz theorem? (as written on wolfram, since I can't find a reference in jackson?) (which granted only holds for finite fields):
[tex]\vec{X} = -\nabla\int_v d^3r'\frac{\nabla\cdot \vec{X}}{4\pi |r' - r|} + \nabla\times \int_v d^3r'\frac{\nabla\times\vec{X}}{4\pi |r' - r|}[/tex]
if we plug in maxwells equations for E & B:
[tex]\vec{E} = -\nabla\int_v d^3r'\frac{\rho}{4\pi \epsilon_0|r' - r|} - \nabla\times \int_v d^3r'\frac{\partial_t \vec{B}}{4\pi |r' - r|}[/tex]
[tex]\vec{B} = \nabla\times \int_v d^3r'\frac{\mu_0 J}{4\pi |r' - r|} + \nabla\times \int_v d^3r'\frac{\mu_0 \epsilon_0 \partial_t \vec{E}}{4\pi |r' - r|}[/tex]
This almost looks as though E & B source each other from their first time derivatives. Now, at this step what happens if I simply set the "real" sources to zero? It seems as though I can rig up some time-varying B to create an E, without sources anywhere, unless I made an error in judgment at this late hour.
(edit: I realized E and B must both vary in time for either to be non-zero, which I guess I already knew deep down, heh. however, it seems to me it is still possible to dispose all other sources.)
Ok, I see what you mean, that one should be careful with the use of the word "causes" when we are talking about several "dynamic state variables" linked by differential equations. I suppose it is a matter of speaking, in a way. I guess that the point is that the way the Maxwell equations are written (in differential form), you can consider them as a "coupled set" of differential equations for E, respectively, B.
That is: you have differential operators in space acting upon E, equal a "source" on the right hand side which can be charge (Gauss' equation), or "changing B-field" (Faraday) ; and you can see the other equations as differential operators acting in space acting upon B, equal 0 (magnetic Gauss), and a combination of current and change of electrical field (Ampere-Maxwell).
If you see, in this way, the E-field as a physical identity by itself (which is problematic, I know), then the "sources" of the E-field are charges and changing B-fields.
In the same way, the B-field seen as a physical identity has as sources, currents and changing E-fields.
Yes, you're right, there's an E-field, sorry (it is the basis of the transformer of course... :blushing: )
kcdodd addressed the issue very clearly: the "sources" are the right-hand sides of differential equations (in space), so they only indicate how the E-field changes from place to place. In fact, in the "space with a torroidal hole", such an E-field is even part of the set of homogeneous solutions (source-free fields).
In normal euclidean space, the "constant E-field everywhere" is also part of the homogeneous solution set (which is usually discarded, by explicit boundary conditions for instance).
I was wrong on that last part. But what I was reacting to, and maybe misunderstanding you, was that I thought somehow that you claimed that Maxwell's equations were somehow wrong.
Now I realize that it is to the phrase "caused by" that you were reacting. As I said above, I think this is a matter of speaking, because in a dynamical system where different physical quantities are related by equations, there is no "cause" and no "effect", but just related quantities. We are however used to think in terms of systems which have their "internal dynamics" and then "external source terms", and we tend to say that external source terms are "causing" a behavior change of the internal dynamics ; often just displayed by the standard way of writing equations, where the right-hand side is the "cause" of the left-hand side.
I understand your "things which happen at the same time cannot cause each other", but if you want to be consistent with that position then I think you cannot make this claim either. The fields and currents and charges all exist at the same time, and particularly in resistive or dielectric media if it doesn't make sense to say that one field causes another then I don't think it makes sense to say that a current or charge causes a field either. I think that the best that you can say wrt causes and remain self-consistent is that a disturbance in the field here and now (or equivalently a change in a current or charge here and now) causes a disturbance in the field later over there (or equivalently a change in a current or charge later over there).
Btw, I am not sure that I agree with your position in general. I think it is not inherently wrong to say that A causes B when A and B are related by a differential equation, with the understanding that it is probably also not wrong to say that B causes A either. Remember that a differential equation is a limit of a difference in some quantity at two different times. So you can consider one time point to be "earlier" and one to be "now" and thus you have the differential term being the cause or you can consider one time point to be "now" and one to be "later" and thus you have the differential term being the effect. In the limit it works out to be the same either way, so I don't think it is an abuse of language or math either way.
Where X is
The point is that if you have a (linear) differential equation of the type:
D[f] = g
then the general solution is of the kind:
f = f_0 + f_p
where f_0 is any solution of the sourceless equation D[f] = 0
and f_p is *A* solution of the equation D[f] = g, for instance, the solution with "zero boundary conditions" (say, f_p(at infinity) = 0).
The "integration from sources" solution is usually f_p, and most of the time, we are happy with it. But you can always add to this solution, any "free field" solution. For instance, you can always add electromagnetic waves, or a constant field to any electromagnetic problem where you only have sources in space, and no extra boundary conditions.
In those cases, it is hard to say that that extra term f_0 is "caused by" charges and currents for instance.
However, it is true that it seems that in our universe, the solutions to the Maxwell equations one should use, are exactly those solutions f_p which DO are only dependent on the currents and charges (apart from the cosmic background radiation...). So, yes, in a way you can say that every *electromagnetic field* finds its "causes" in currents and charges (and magnetic dipoles - because the magnetic field of an electron doesn't come from any current).
However, if you consider the E and B fields as "separate entities", then you should also allow people to colloquially say that the "changing E-field causes (is a source term in the diferential equation for) a B field and vice versa", no ?
I think there is some physics that needs to be clarified beyond direct interests in cause and effect.
An ideal inductive element with constant current generates no external electric fields where there are no charges or currents. Obviously any magnetic fields will be static fields. In a current free region of space dB/dt=0 no matter what the shape of the inductor This obtains electric fields of zero magnitude.
Before I go any further, bjacoby, I'm sorry I was unduly harsh. I felt you were derailing the question posed be the OP.
We should be careful whether we are specifying an inductor with changing or static currents.
In the case where the currents are non-static, the inductor radiates electromagnetic energy. With a sinusoidally varying sheet of current an ideal infinite solenoid will generate both electric and magnetic fields that also vary sinusoidally and propagate outward at velocity c.
All AC transformers are sources of electromagnetic radiation. The transformer equation is only true in the near field limit, or where the windings are bathed in an electric field of the same phase. In practical terms, this is nearly always the case.
As far as I know, any arrangement of the 4-vector potential A= (rho, A) over the spacetime manifold is physically permissible.
When the electric and magnetic fields are not viewed as separate fields but simply time and space derivatives of the 4-vector potential, any questions of cause and effect of one by the other loss meaning.
I’m not sure how one should deal with cause and effect of an evolving A field upon itself. A similar question arises with the space time metric in questions like “why is space expanding?”
We can take this idea of A field derivatives one step further to a point that bothers most physicists, and claim that charge and current are simply second derivatives of A. It’s not really a claim, but only a mathematical conclusion within the constraints of classical electromegnetism. But now everything goes wrong, and charge has a wave equation that propagates at the speed of light, so we have to include the peculiar rule that second derivatives of A are always attached to mass.
We implicitly do this anyway, when we work with Maxwell’s equations and the Lorentz force equation.
I'm not sure I follow your last line of logic Phrak, although now we really are leaving the original post. I assume that by "the second derivatives of A", you mean
[tex]\nabla^2 A = J[/tex]
or, also written:
[tex] \Box A = J[/tex]
This is clearly not a "matter wave" equation. It's just an inhomogeneous wave-equation of the potentials.
[tex]\nabla^2 A = 0[/tex]
is perfectly valid.
Correct me if I'm wrong as I don't have any particular references to experiment at my fingertips, but it is my understanding that experiment has shown time variable charge (which is also a current) creates fields and that those fields travel outward from that source at the speed of light. In other words the fields are "retarded". That includes E, D, B, H, A etc all of which are retarded at a distance from the current sources. Thus your assertion that fields and charges all exist at the same time is not correct. In fact due to retardation, as the fields propagate through space one could actually remove the charges so they did not exist but points at a distance would see no evidence of that until the fields from that event reached there.
Your point that in a differential equation there is a differential time difference is an interesting one. However, one has to ask if the limit is actually being taken. I suggest it is and in the limit the times are identical and hence in the limit causality would then not be correct terminology.
First, this is wrong:
The A potential can't be specified consistently over all spacetime with randomly chosen values, but over a space-like 3D submanifold--for instance, the lab frame at some time, t.
or, also written:
is perfectly valid.
I made a notational error. A = (phi,A), where phi is the electric potential and A is the magnetic potential.
All classical electromagnetism can be delt with using exterior derivatives and differential forms in four dimensions. My internet connection is acting up or I would give you a specific link. Wikipedia has some mention of maxwell's equations in differential forms, I believe.
The actual equations are simple and elegant but meaningless if you don't know the notation first.
But notice that A(t,x,y,z) = (phi,A)(t,x,y,z) is a true Lorentz invariant vector field over spacetime.
J(t,x,y,z) = (rho,J)(t,x,y,z) is also a Lorentz invariant vector field over spacetime. J is the current density and rho is the charge density.
The electric and magnetic fields are first derivatives of A. One solution of the derivatives of the electric and magnetic fields results in the wave equations of light. So the wave equations of light are third(edited) derivatives of the 4-vector field, A(t,x,y,z).
(The vacuum wave equation is expressed as 0=d*d*dA (edited). Elegent but meaningless without the decoder ring.)
What can be done with A can be done with J except for the fact that charge is attached to mass. Naively ignoring this for a moment we would conclude that wave equations in J propagate at the same velocity as those of A. But, of course, they don't.
  • #31
And how do you obtain a current? Typically by using a field, usually either an electric field in a battery or a magnetic field in a generator.
Locally, it is clear that the fields and charges do all exist at the same time. And from the structure of the equations themselves there is no reason for you to single out one and say that this causes that but the rest can't cause each other because they are simultaneous. Once you stop looking at the equations and start looking at the retarded solutions then you can still have that a retarded field causes a current or a charge, in fact that is how receiving a radio signal works.
Again, I understand your point, but I think that you are applying it inconsistently when you say categorically that charges and currents are the cause and fields are the effect and that fields can't cause each other because they are simultaneous.
  • #32
Phrak said:
First, this is wrong:The A potential can't be specified consistently over all spacetime with randomly chosen values, but over a space-like 3D submanifold--for instance, the lab frame at some time, t.I made a notational error. A = (phi,A), where phi is the electric potential and A is the magnetic potential.
Yes, please post a reference because I have never heard of a matter wave interpretation. And I believe that the wave equations are the second, not third, derivative of A. In fact I don't know of any third derivatives anywhere.
I would like to point again to a post I made earlier...
I am fairly sure this is accurate, with the caveat that this is to be integrated using a retarded time. In other words, the global field as viewed from a point must be self consistent within the past light cone of that point. helmholtz theorem really would not make sense otherwise (you surly can't integrate outside the past light cone). There are two interpretations to this. Either (a) all field and sources are "simultaneous" within the past light cone (we are simply solving a differential equation on a space-time surface), or (b) all fields and sources on the past light cone "caused" the field value at the point to which the cone is attached (since the entire integral exists in the past of that point). It seems both are valid views, but both exist for fields and sources, not just one.
  • #33
Please don't misunderstand me. The mater waves--actually, charge waves, are unphysical; they only occur with massless charge. They have come up, or should eventually come up in solid state physics, a branch of physics I know nothing about. Maybe Zapper Z can comment.
Second derivatives with respect to space and time of E and B, d'Alembertian E=0 and d'Alembertian B[/b]=0, are the vacuum equations, of course. E and B are both first derivatives of A and phi. So the wave equation is third order in A.
But nevermind all that. I've become curious about your previous post. I don't know what the physical significance of d'Alembertian A is. Any ideas?
I know that there is one second derivitive of A--being first derivative in E and B, that yields the charge continuity equation. I don't know if there are others.
  • #34
My interpretation would be closer to b. The definition of "simultaneous" described by a is not symmetric (meaning that if event A is simultaneous with B that does not imply that B is simultaneous with A), which is not the usual way to think of simultaneity.
  • #35
Phrak: When someone says the EM wave equation, this is what I think of. Not of E and B, but of A.
[tex]\nabla^2\phi - \partial^2_t\phi = -\rho[/tex]
[tex]\nabla^2\vec{A} - \partial^2_t\vec{A} = -\vec{J}[/tex]
DaleSpam:
I see your point. The value of B depends on A, but not the other way around, since we don't take the advanced solution.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
