Is the positive terminal ALWAYS high potential?
In summary, the positive terminal in a circuit is not always associated with high potential and its potential can change depending on various factors. It is often referred to as the "high potential" terminal because it is connected to the voltage source. The placement of the positive terminal in circuit diagrams can vary and it determines the direction of current flow in a circuit.
charge here
Is the positive terminal always high potential, regardless of if an electron or proton is placed in the "charge here" area somewhere between the two plates, and the negative terminal is always low potential, no matter what?
Mind you, this is high school grade 12 physics.
Positive terminal of WHAT? Is this a battery? A capacitor?
Since the "positive terminal" is DEFINED as being the terminal with the higher potential, I think the answer is yes, but your question is unclear.
And what's this about a proton? What does that have to do with electric potential?
Related to Is the positive terminal ALWAYS high potential?
1. Is the positive terminal always associated with high potential?
No, the positive terminal can have varying potential depending on the circuit and its components. It is not always the case that the positive terminal will have the highest potential.
2. Why is the positive terminal often referred to as the "high potential" terminal?
The positive terminal is often referred to as the "high potential" terminal because it is usually connected to the voltage source or the power supply, which provides a higher potential compared to the negative terminal.
3. Can the potential of the positive terminal change?
Yes, the potential of the positive terminal can change depending on the voltage source, resistance, and other components in the circuit. It is not a fixed value and can vary in different situations.
4. Is the positive terminal always located on the right side of a battery symbol in circuit diagrams?
No, the placement of the positive terminal in circuit diagrams can vary depending on the convention used. Some diagrams may have the positive terminal on the left side, while others may have it on the right side. It is important to check the legend or key for the specific circuit diagram to understand the placement of the terminals.
5. How does the potential of the positive terminal affect the flow of current in a circuit?
The potential of the positive terminal determines the direction of current flow in a circuit. The current will flow from the positive terminal to the negative terminal, as it moves from high potential to low potential.
  • Electromagnetism
