Number Theory - Proving x is not a perfect square?
In summary, the conversation discusses a question about proving a specific number is not a perfect square. The conversation also explores ways to prove the square root of this number is irrational. The conversation includes suggestions, methods, and examples of products of irrational numbers and their rationality.
Cornell2017
Hey Guys,
This is my first post to Physics Forums. If I posted this question in the wrong area or am violating some other etiquette, please let me know!
I'm working on a proof and am currently stuck. I'm trying to prove that x (a weird number, an infinite product to be specific), is NOT a perfect square. At first I thought I could say that if x converges to a value between two perfect squares, it then can't be a perfect square. Then I realized that 1, 4, 9, 16, 25,... are not the only perfect squares. There are also 0.16 (0.4^2), 6.25 (2.5^2), etc. How could I go about showing that x is a perfect square? or that sqrt(x) is irrational?
I'd really appreciate some guidance on this!
Thanks so much!
Justin
Mathematics news on Phys.org
Usually perfect square refers to integers. That shouldn't be too hard (well, maybe it is... I don't really know what the problem is). If you want to show that sqrt(x) is irrational you might be able to follow the method used for sqrt(2), but, again, the specifics matter.
I tried using the method for sqrt(2), but ran into problems because radicand is not an integer. Any ideas on proving irrationality for the square root of a non integer?
Apparently this is the product of an infinite series of rational numbers.
Is there a way of counting the number of any particular prime value in either the numerator or denominator?
For example, can you show that no matter how many terms are evaluated, the total number of 2's in the numerator and denominator will always be odd? If so, then the square root will be irrational.
Bear in mind that may not be a firm yes or no answer. Take this product series, for example:
(2/1) (2/4) (2/9) (2/16) (2/25) (2/36) (2/49) ...
The square root of that value is both rational and not - or perhaps always undefined.
On the other hand:
(4)(1/4)(4)(1/4)...
would always be rational - assuming it is even defined.
Scott,
Thanks for the reply, which will surely be useful somepoint in the future. For this specific problem, though, it is quite the opposite actually. Every number is *irrational*. The product contains a bunch of nth roots of 2 and a bunch of nested radicals. How could I go about proving irrationality for an infinite product of irrational numbers?
Thanks!
Since every number is irrational, that says a lot.
We have to assume that the series approaches 1, otherwise the product will not approach a set number and will be undefined.
But even if it approaches 1, we still have a problem because, being irrational, it can never reach 1.
Let's call the ratio of two perfect squares that is not a perfect square a "good square". A good square is what we are looking for and good squares are always rational.
Let's say that up to term "n" we have a good square. Then we know that on term n+1 it will not be a good square. This suggests that the product of an infinite series of irrationals can never be rational - but I'm not actually convinced of this. I think that I could write such a series if I took the time.
The key thing to do is to keep tally of the terms in the series to see if the irrationals combine to form rationals.
For example, let's say every element of the series is a rational number to a power. Then perhaps you can sum all the exponents of any given prime in the numerator and subtract all the exponents of that same prime that appear in denominators. If the result is not an even number, then you aren't going to end up with a good square. Of course, the same can be done with any prime.
The problem is that there are products that are always irrational, but the limit can still be rational
Consider the function
[tex] f(x) = \prod_{n=1}^\infty 1+e^{-nx}[/tex]
is defined for x>0
lim x->0 f(x) = infinite
limit x->inf f(x) = 1,
it is strictly decreasing
it can take on all values >1
That's incredibly helpful! Thank you so much everyone!
FAQ: Number Theory - Proving x is not a perfect square?
1. How can I prove that a number is not a perfect square?
To prove that a number is not a perfect square, you need to show that it cannot be expressed as the square of an integer. This can be done by using different mathematical techniques such as prime factorization, modular arithmetic, or the method of contradiction.
2. Can I use a calculator to determine if a number is a perfect square?
Yes, you can use a calculator to find the square root of a number and check if it is an integer. If the square root is not an integer, then the number is not a perfect square.
3. Are there any specific patterns or rules to identify non-perfect square numbers?
Yes, there are certain patterns and rules that can help you identify non-perfect square numbers. For example, any number ending in 2, 3, 7, or 8 cannot be a perfect square. Additionally, if the sum of the digits of a number is divisible by 3, then the number is not a perfect square.
4. Can I prove that a number is not a perfect square without using mathematical equations?
Yes, you can prove that a number is not a perfect square without using mathematical equations. One way to do this is by using a geometric approach, where you draw a square with an area equal to the given number and show that it cannot be divided into equal smaller squares.
5. Is it possible for a number to have a square root that is not a perfect square?
Yes, it is possible for a number to have a square root that is not a perfect square. These numbers are called irrational numbers, and they cannot be expressed as a fraction of two integers. Examples of irrational square roots include √2, √3, and √5.
