What makes the gas lamps light a certain color?
In summary: As with all colours, white is just a name your brain gives to the combination of signals which your three, wavelength selective, sensors produce. 'Colour' is just in your mind.
JosephK
40
Hi,
Looking at the emission spectra of Mercury, for instance, how do the lines (I count 9 in the visible range: dark red, lighter red, orange, 3 yellows, green, purple, dark purple) superimpose to give light blue glow?
My lab partner said that blue is the average of the wavelengths, such as when red and blue filters are put ontop of each other) would give green. But how does that explain white light, which can break down into basically every color. Wouldn't the average give green-yelow?
Joseph
Science news on Phys.org
This has to do with the way the eye works. There are three kinds of visual receptors for color, which are sensitive to different wavelength ranges. They send signals to the brain, which combines them to produce the sensation of color. Googling on phrases like "biology of color perception" and "neurophysics of color perception" might give useful results.
As with all colours, white is just a name your brain gives to the combination of signals which your three, wavelength selective, sensors produce. 'Colour' is just in your mind. It so happens (evolution took care of it) that humans all more or less agree about the way that different combinations of 'primary' colours can be mixed to match the spectra of light from most sources / objects. Having learned the agreed or learned 'names' for colours and shades, we have a fairly good consensus about what to call a new colour (unless you are buying clothes with your wife - when all bets are off).
Our colour vision is a fantastic system, based on a very crude analysis, for us to get 'just enough' information about our surroundings to be useful. But, as I have often said, the eye is not a spectrometer - because it doesn't need to be. It can spot shades of green - to recognise useful and dangerous plants, it is very perceptive of 'skin tones' - so it will recognise emotions etc etc but it can be fooled almost totally when looking at a colour TV picture that uses just three fairly pure primary display RGB colours. You really 'believe' what the TV display is showing you (colours, not programme content!).
JosephK said:
Hi,
It may be 9 lines (depends on how sensitive is your instrument) but the blue and green are the strongest by far and they pretty much determine the color we perceive.
You can see the relative intensities here, for example:
http://physics.nist.gov/PhysRefData/Handbook/Tables/mercurytable2.htm
Thank you for your question about the color of gas lamps. I can say that the color of the light emitted by gas lamps is determined by the specific elements present in the gas and their corresponding emission spectra. In the case of mercury lamps, the light is produced by the excited mercury atoms emitting photons of specific wavelengths as they return to their ground state. This results in the characteristic lines that you have observed in the visible range, including the blue line that contributes to the overall color of the light emitted.
Your lab partner's explanation about blue being the average of the wavelengths is not entirely accurate. While it is true that mixing red and blue light can result in green, the color of the light emitted by a gas lamp is not simply the average of all the wavelengths present. This is because the intensity of each wavelength also plays a role in determining the overall color. In the case of white light, it is a combination of all the visible wavelengths in the spectrum, resulting in a white appearance.
I hope this helps to clarify the concept of color in gas lamps. If you have any further questions, please don't hesitate to ask. As scientists, it is our job to continue exploring and understanding the world around us. Keep asking questions and seeking answers!
1. What is the source of light in gas lamps?
The source of light in gas lamps is the burning of a gas fuel, such as natural gas or propane. This produces a flame that emits light.
2. Why do gas lamps emit different colors of light?
The color of the light emitted by a gas lamp is determined by the type of gas fuel being burned. Different gases produce different colors when they are burned. For example, natural gas produces a yellow flame, while propane produces a blue flame.
3. How does the color of the gas lamp affect its brightness?
The color of the gas lamp does not affect its brightness. The brightness of a gas lamp is determined by the amount of fuel being burned and the design of the lamp, not the color of the flame.
4. Can the color of the gas lamp be changed?
Yes, the color of the gas lamp can be changed by using different types of gas fuels or by adding elements, such as salts, to the fuel. This is often done for decorative purposes or to create a specific ambiance.
5. Are there any safety concerns with colored gas lamps?
No, there are no additional safety concerns with colored gas lamps compared to regular gas lamps. As long as the lamp is properly maintained and the fuel is burned safely, the color of the flame does not affect its safety.
  • Classical Physics
