Diffraction: rectangular aperture and gaussian beam
In summary, the FKF can be applied to gaussian beams and can be used to describe their diffraction through rectangular apertures in the far-field assumption.
Enialis
Is the Fresnel-Kirchhoff formula (FKF) valid also for gaussian beams? I a book starting from the gaussian intensity:
[tex]U_0(x,y)=\sqrt{\frac{2}{\pi\omega_0^2}}\exp\left(-\frac{t^2+s^2}{\omega_0^2}\right)[/tex]
it said that using the FKF in free space the gaussian beam spreads (in far-field assumption). It concludes that the field can be expressed with a standard Gaussian distribution but with complex exponential rather than real. How can be it proved?
Now my question is: what happen if there is a diffraction through rectangular aperture to this gaussian beam? What is the correct theory to use in far-field assumption?
Science news on Phys.org
The Fresnel-Kirchhoff formula (FKF) is indeed valid for gaussian beams. In the far field assumption, the FKF can be used to describe the diffraction of a gaussian beam through a rectangular aperture. The field can be expressed with a standard Gaussian distribution but with complex exponential rather than real. This can be shown by using the convolution theorem, which states that the product of two Fourier transforms is equal to the Fourier transform of their convolution. Thus, the diffracted field can be expressed as the convolution of the incident beam and the impulse response of the aperture, which can be calculated using the FKF.
Yes, the Fresnel-Kirchhoff formula (FKF) is valid for gaussian beams as well. The FKF is a general formula that describes the diffraction of any type of wave, including gaussian beams.
To prove this, we can start with the FKF equation:
U(x,y) = \frac{1}{i\lambda}\int\int_{S} U_0(x',y')\frac{e^{ikr}}{r}dxdy
Where U(x,y) is the diffracted field, U_0(x',y') is the incident field, r is the distance from the aperture to the observation point, and S is the aperture.
We can substitute the gaussian beam expression for U_0(x',y'):
U(x,y) = \frac{1}{i\lambda}\int\int_{S} \sqrt{\frac{2}{\pi\omega_0^2}}\exp\left(-\frac{(x'-x)^2+(y'-y)^2}{\omega_0^2}\right)\frac{e^{ikr}}{r}dxdy
Then, we can use the identity:
\int_{-\infty}^{\infty} e^{-ax^2}dx = \sqrt{\frac{\pi}{a}}
To simplify the integral:
U(x,y) = \frac{1}{i\lambda}\sqrt{\frac{2}{\pi\omega_0^2}}e^{ikr}\int\int_{S} \frac{e^{-\frac{(x'-x)^2+(y'-y)^2}{\omega_0^2}}}{r}dxdy
Next, we can use the Gaussian integral:
\int_{-\infty}^{\infty} e^{-ax^2+bx}dx = \sqrt{\frac{\pi}{a}}e^{\frac{b^2}{4a}}
To further simplify the integral:
U(x,y) = \frac{1}{i\lambda}\sqrt{\frac{2}{\pi\omega_0^2}}e^{ikr}\int\int_{S} \frac{e^{-\frac{(x'-x)^2}{\omega_0^2}}e^{-\frac{(y'-y)^2}{\omega_0^2}}}{r}dxdy
We can then
FAQ: Diffraction: rectangular aperture and gaussian beam
1. What is diffraction?
Diffraction is the bending of waves around obstacles or through small openings. It is a fundamental phenomenon in physics and can be observed with all types of waves, including light, sound, and water waves.
2. What is a rectangular aperture?
A rectangular aperture is a rectangular-shaped opening or hole through which waves can pass. It is commonly used in experiments to study diffraction and can be created artificially using a screen with a rectangular slit.
3. How does a gaussian beam differ from a rectangular aperture?
A gaussian beam is a type of laser beam that has a bell-shaped intensity profile, while a rectangular aperture has a uniform intensity distribution. In terms of diffraction, a gaussian beam will produce a diffraction pattern with a central bright spot surrounded by concentric rings, while a rectangular aperture will produce a diffraction pattern with a central bright spot and additional bright spots at the corners of the rectangle.
4. What factors affect the diffraction pattern produced by a rectangular aperture?
The size of the aperture, the wavelength of the waves, and the distance between the aperture and the screen on which the diffraction pattern is observed are all factors that can affect the diffraction pattern produced by a rectangular aperture. Additionally, the shape and smoothness of the aperture edges can also have an impact on the diffraction pattern.
5. How is diffraction of a gaussian beam used in real-world applications?
Diffraction of a gaussian beam is used in various applications, such as laser cutting, laser holography, and laser microscopy. It is also used in the study of optics and can provide information about the size and shape of objects that are too small to be observed with traditional optical microscopes.
