Car Acceleration: Gears, Gear Ratio, & More
In summary, the conversation discusses the specifications and calculations involved in creating a racing game for the XBox. The car's specs, including air density, mass, red line, drag coefficient, and tire specifications, are noted. The gear ratios and other details, such as lateral acceleration and weight distribution, are also mentioned. The conversation also delves into finding torque at different engine speeds and the effects of traction and tires on acceleration. The conversation concludes with a suggestion to seek additional resources for more precise calculations.
VMail
Hi I am making a racing game for the XBox, I need some info on the following Gears, Gear Ratio and Acceleration, basically I want to know how a real car moves, if you are insteasted in testing the PC version then let me know
Car Spec
air density = 1.29kgm-3
mass = 1550kg
red line = 8500rpm
drag coefficient (cd) = 0.34 (not an official number)
height = 1.36m
width = 1.785m
frontal area = height × width = 2.4276m2 (only an approximation)
wheelbase = 2.665m
tire = 245/40ZR18
tire radius = 0.3266m (this number is calculated from the tire spec)
torque = 392Nm@4400rpm
power = 206000W@6800rpm
1st gear ratio = 3.827
2nd gear ratio = 2.36
3rd gear ratio = 1.685
4th gear ratio = 1.312
5th gear ratio = 1
6th gear ratio = 0.793
reverse gear ratio = 3.28
final drive ratio = 3.545
lateral acceleration = 0.94g on skidpad of 300ft radius weight distribution (front/rear) = 57%/43
minimum turning radius = 5.6m
To make things simple, the throttle can only be up or down
I want to know quickly the car will move, say like from 0MPH to 30MPH, staying in 1st gear (or KPH which ever is easy, I can always convert it later) (also i haven't given the distance)
also I've been given torque = 392Nm@4400rpm, how would i find the torque at 5000rpm?
Horsepower = Torque x RPM / 716
Torque in kilograms per meter --- 1kgm = 9.8 NM
Horsepower in spanish CV unit (I think its more or less same as HP) --- 1KW = 1.36 CV/HP
So you could calculate torque at 5000 rpm if you had the horsepower figure at the same egine speed.
That engine has an output of 245.81 hp at 4400 rpm and 280.16 hp at 6800 rpm.
You have not specified whether it is FWD, RWD, or AWD. Especially in the first 2 cases, it will be traction-limited and the tires will have a bigger effect on acceleration 0-30 than the torque. If it is not AWD with traction control, you will also need the height of the centre of gravity, so you can calculate the weight transfer.
Most modern NA engines have flat torque curves up to about 80% of redline where it begins to drop.
most cars a FWD, so it a FWD now, and no traction I think (a lot of wheels spinning)
I don't think so. Too much traction without enough torque could hurt the launch more than a little spin off the line (been there, done that). Of course, it's easy to overpower the tires on a high-torque rwd car with regular street radials, but good drivers know how to feather the launch so that the amount of power put to the ground is balanced with the available traction. Stickier tires will allow you to launch harder and put a little less emphasis on the driver, but you'll need the low end torque or short gearing to take advantage of it.
Low speeds like 0 to 30mph are easy because air drag is negligible. Acceleration in g's is
[tex]{f_f\over {1\over\mu} + {h\over L}}[/tex]
where [tex]\inline{\mu}[/tex] is the lateral g's (coefficient of friction), [tex]\inline{f_f}[/tex] is the fraction of weight on the front, h is the height of the CG (I estimate 0.5m), L is the wheelbase. Plugging in your numbers gives 0.45 g's or 14.4 ft/s/s. 30mph is 44 ft/s, so the time to get there is 3.05 seconds. The same specs for RWD give 2.76 s.
This problem is a little involved for an online forum. People take courses on this stuff. Go to the library and pick up some books on auto engineering. Even that won't help you very much with tires, since real data on them is almost impossible to come by (krab's approximation isn't very good). You'll have to experiment, and see what feels right.
You'll also need a torque curve (which you can guess at from peak torque and power figures - just draw a reasonable looking graph which satisfies both conditions) at the wheels - not the usual net rating.
Then you have to worry about how the differential(s) distributes torque, and the rotational inertia of the various driveline portions.
Springs and shocks also affect how the car launches.
If you're just making a simple arcade game (ie not a sim), then you can get away with less, but you didn't say. Ask more specific questions.
I failed A Level Physics, not because I was fick, just that I needed more time in the exam(they didnt cover any of this in the subject), yeah will be in the library in two weeks, I am learning loads of stuff on here, I though making a 3D racing car games would be easy, The game will be like Need For speed Underground, so that calculation don't have to be 100% accurate but will need to make it look realistic (also will be ignoring wind)
You should probably browse around this site a bit
http://www.racer.nl/
He's making a game that's supposed to do the physics "right," and has a lot of documentation on it (free source too I think). It might give you some ideas.
I don't think krab formula is correct as there is nothing referanceing the gears
Show me some data that disagrees. I've found it works very well. If you have enough power to break traction up to 30mph (which you do), then the gear ratio is not relevant; only the coefficient of friction and the downward force on the driving tires matter.
Anyway, I did the other calc.s for you.
1/4 mile: 14.11 sec @110.9 mph
top speed: 163 mph
0-60: 6.86 sec
60 ft time: 2.89 sec
A graph of driving force versus speed in each gear is http://trshare.triumf.ca/~baartman/vmail.png The Green curve is your traction limit. Since the drive is FWD, this is rather low. The Red curve is air resistance. Where it crosses your white curves is top speed. The Blue curve is the performance you would get if you had an ideal gearbox which always kept you at peak power.
Its a bit hard for me to explain this, 1st and 2nd gear gives different acceleration
eg 0-30MPH in 1st gear will take 3.05sec
but what if you drive 0-15 in 1st gear and switch to 2nd from 15-30MPH
both will take different times to get to 30MPH
Well 30 mph is only 5300 rpm is 1st gear, so there would be no point in shifting before then. Shifting near 7000 rpm would be optimal for the 1->2 shift if that doesn't hit the rev limiter.
If your torque curve is reasonably flat, you should be able to smoke your tires through almost all of 1st gear, so max acceleration is reached at the traction limit (part throttle). This is approximated through krab's formula.
15mph in second gear is only 1600rpm. You won't have enough power there, especially if it is a turbo (which I don't know). I put more realistic torque numbers in the graph. (Also the link was broken.) Look at the graph and I think you'll understand. http://trshare.triumf.ca/~baartman/vmail.png
does the graph show that top speed in 1st is approx 40MPH
how would I determin how quickly the lbs goes up?
Look at the graph. Optimum shift points are where the curves cross.
I don't understand the question.
In my car (Toyota Yaris) I can go 0-60MPH in 8.3sec, Toyota say 0-60MPH is 12.8Sec. I did it 8.3sec because I change from 1st to 2nd at 30MPH.
If I drove properly
1st 0-15MPH
2nd 15-30MPH
3rd 30-40MPH
4th 40-60MPH
the second way would take longer because I've changed gears too quickly, so that's what I need the formula for
If I drove properly
1st 0-15MPH
2nd 15-30MPH
3rd 30-40MPH
4th 40-60MPH
Assuming you have the 1.5, toyota claims 9.0 seconds (not far off from your estimate)
If you don't have the 1.5, I'd be happy to show you the fault in your timing equipment, since you didn't go that fast
its a 1.3 CDX
Related to Car Acceleration: Gears, Gear Ratio, & More
1. What is car acceleration?
Car acceleration is the rate at which a car increases its speed over a certain period of time. It is typically measured in miles per hour (mph) or kilometers per hour (km/h) and is influenced by various factors such as engine power, weight of the car, and road conditions.
2. How do gears affect car acceleration?
Gears play a crucial role in car acceleration by transferring power from the engine to the wheels. The gear ratio, which is the number of times the engine turns for each turn of the wheels, determines how quickly a car can accelerate. Lower gears provide more power and faster acceleration, while higher gears are more suitable for maintaining speed.
3. What is the difference between manual and automatic transmission in terms of acceleration?
Manual transmission requires the driver to manually shift gears, while automatic transmission does this automatically. In terms of acceleration, manual transmission allows for more control over gear shifts and can often result in faster acceleration. However, modern automatic transmissions have become more advanced and can also provide quick acceleration.
4. What are the factors that affect gear ratio and acceleration?
The gear ratio and acceleration of a car can be affected by several factors, such as the size and weight of the car, the type of transmission, the engine power, and the road conditions. Additionally, the type of gear system, such as a continuously variable transmission (CVT) or a traditional manual transmission, can also impact gear ratio and acceleration.
5. Can changing gears too quickly or too slowly affect acceleration?
Yes, changing gears too quickly or too slowly can affect acceleration. Shifting gears too quickly can cause the engine to bog down and decrease acceleration, while shifting gears too slowly can result in the engine revving too high and wasting fuel. It is important to shift gears at the appropriate time to achieve optimal acceleration and fuel efficiency.
  • Mechanical Engineering
14K
  • General Engineering
44K
