Edwin
- 162
"Surface Volume" in 4-d graph: Euclidean Geometry Question
Suppose you have a smooth parametrically defined volume V givin by the following equation.
f(x,y,z,w)= r(u,s,v) = x(u,v,s)i + y(u,v,s)j +z(u,v,s)k + w(u,v,s)l
Consider the vectors ru=dr/du, where dr/du is the partial derivitive of r with respect to the parameter u. Similarly, rv = dr/dv, rs=dr/ds are the partial derivitives of r with respect to the parameters v and s, respectively.
I presume that ru(u0,v0,s0), rv(u0, v0, s0), and rs(u0,v0,s0) form a three dimensional parallelpiped that represents the rate of change of the three dimensional surface volume in four dimensional Euclidean space.
The angle theta between ru and rv is arccosine((ru*rv)/(|ru||rv|))
Similarly, the angle phi between ru and rs is arccosine((ru*rs)/(|ru||rs|).
The height h1 of the parallelogram p1 formed by ru and rv is the magnitude of the projection of rv onto the perpindicular of p1 and is equal to
|rv|sin(theta). The area A1 of this parallelogram is
|ru|*h1 = |ru||rv|sin(theta).
The height h2 of the parallelogram p2 formed by ru and rs is the magnitude of the projection of rs onto the perpindicular of p2, and is equal to |rs|sin(phi)
The area of A2 of this parallelogram is |ru|*h2 = |ru||rs|sin(phi).
The volume of the parallelpiped V = the area of either of the parallelograms times the height of the other parallelgram.
A2*(h1) = A1*(h2) =|ru||rv||rs||sin(phi)*sin(theta)|
Based on this, I conjecture the following:
If a smooth parametrically defined volume V is givin by the following equation:
Where (u,s,v) are elements of E, and
V is covered just once as (u,v,s) varies throughout the parameter domain E, then the "Surface Volume" is
the tripple integral over E of =|ru||rv||rs||sin(phi)*sin(theta)|dV
Where the angle theta is arccosine((ru*rv)/(|ru||rv|)),
and the angle phi is arccosine((ru*rs)/(|ru||rs|).
Does this sound accurate?
Inquisitively,
Edwin
Inquisitively,
Edwin
