In the following figure, the space b/w the glass lenses is filled with
In summary, the conversation discusses the calculation of the focal length of a system of lenses, specifically the use of lens maker's formula and the substitution of refractive indices. It is agreed that the refractive index of glass with respect to water should be used in the formula, and the basic equation for refraction at a curved single interface is mentioned.
zorro
1,384
In the following figure, the space b/w the glass lenses is filled with water. We have to find the focal length of the system (radii of curvature, refractive indices given)
[URL]http://203.196.176.41/VLEBT_RootRepository/Resources/6c32207c-7c5a-4462-b90c-89b0c196bc72.gif[/URL]
Now to calculate the focal length of the system of lenses, we have to calculate the focal length of each lens. To find the same for water lens, we use lens maker's formula-
1/f = (μ-1)(1/R1 - 1/R2)
Why don't we substitute μ as gμw instead of aμw as given in all books? Doesn't the light travel from glass to water?
Science news on Phys.org
if i understood your question rite, it is 100 % correct to use refractive index of glass wrt water in this sum...
can you show me a source for that claim?
Use the basic formula for refraction at a curved single interface twice,factoring in the assumption of thin lenses.You will see that terms cancel out and the final equation will agree with what you are saying.The 1 in the lens maker's formula you brandished is because the refractive index of air is very close to 1.If I remember correctly the basic equation of which the lensmaker's formula is a special case is:
n1/u + n3/v = n2-n1/R1 + n3-n2/R2
Where n1,n2,n3 are refractive indices of medium to the left,the lens and the medium to the right respectively.
I would like to clarify that the value of μ (refractive index) should not be substituted as gμw (refractive index of glass) for the water lens. This is because the light does not travel from glass to water in this system. The light instead travels from air to glass, then from glass to water, and finally from water to air. Therefore, the correct value to use for μ in the lens maker's formula is aμw (refractive index of air). This is a common mistake and it is important for accurate calculations to use the correct values in the formula.
1. What is the purpose of filling the space between glass lenses in this figure?
The space between the glass lenses is typically filled with a transparent material, such as air or a specific type of liquid, to help control the light that passes through the lenses. This helps to improve the clarity and quality of the image produced by the lenses.
2. What types of materials can be used to fill the space between glass lenses?
Air is the most common material used to fill the space between glass lenses, as it is readily available and has a similar refractive index to glass. Other materials, such as water, oil, and even specialized gels, can also be used depending on the specific application and desired optical properties.
3. How does filling the space between glass lenses affect the optical properties of the lenses?
Filling the space between glass lenses can have a significant impact on the optical properties of the lenses, such as the focal length, aberrations, and light transmission. By choosing the right material to fill the space, scientists can control these properties to achieve the desired results.
4. Can the material used to fill the space between glass lenses be changed?
Yes, the material used to fill the space between glass lenses can be changed depending on the specific needs of the experiment or application. Different materials can be used to manipulate the light passing through the lenses and achieve different results.
5. How does the distance between the glass lenses affect the choice of material to fill the space?
The distance between the glass lenses is an important factor when choosing the material to fill the space. The refractive index and thickness of the material must be carefully considered to ensure the lenses function properly and produce the desired optical effect.
