Electric current density in conductors not resembling a wire
In summary: Yes, exactly! If the plate is thin enough, there won't be much current variation through the thickness, and if both corner connections are made evenly along the corner edge, there'll be no thickness variations of current at all.
Crusoe
Let's say you have a square plate with a voltage applied across two opposite corners, connected by the hypotenuse.
Presumably, the electric current density distribution throughout the plate would be such that it would follow the path of minimal resistance, i.e. through the hypotenuse.
If you had a way of measuring the current density at a point in the plate (e.g. IR thermography) would the readings show that the current density has a spatial distribution throughout the plate and indeed even a change through the thickness?
What factors determine how the charge carriers are distributed in a conductive medium?
The current would be maximum along the hypotenuse, but would also be spatially distributed across the entire plate. Under electrostatic conditions in conductive media, the voltage [itex]\phi[/itex] obeys the equation [itex]\nabla^2\phi=0[/itex] (http://en.wikipedia.org/wiki/Laplace%27s_equation" ). The current is then [itex]\bold{J}=\sigma\bold{E}[/itex], where the electric field [itex]\bold{E}=-\nabla\phi[/itex]. As it happens, this equation also describes heat flow, so it might be useful to visualize the equivalent problem of maintaining a temperature difference between the two opposite corners. Heat will flow through the entire plate, but mostly in the area near the hypotenuse. The other two corners will stabilize at half the voltage difference (equivalently, half the temperature difference).
If the plate is thin enough, there won't be much current variation through the thickness, and if both corner connections are made evenly along the corner edge, there'll be no thickness variations of current at all. Does this make sense?
Yes it does, thanks for the clear response! :)
Is an intuitive interpretation of [itex]\nabla^2\phi=0[/itex] in the context of electrical voltage, that the net or sum change in voltage equals zero? IOW the vector calculus form of Kirchoff's Second Law for circuits.
Can you recommend a good online introductory source (or failing that, a book) for me to read up on this? My background is in aerospace engineering.
Well, the sum of voltages around the battery-plate circuit does equal zero, of course. But Laplace's equation here is really saying that every field line that leaves one of the corners must end up at the other corner. And perpendicular to the field lines are the contours of equal potential.
The electrostatics details are covered in many classical physics texts.
Ah, thanks. I did electrostatics in college physics many years ago.
A click just went off in my head, now I see the relevance to electrostatics. You just substituted the permittivity of free space for separated charges, with that of the metal plate.
What is electric current density?
Electric current density is the amount of electric current flowing through a unit area of a material. It is typically measured in amperes per square meter (A/m²).
How is electric current density different in conductors not resembling a wire?
In conductors that do not resemble a wire, the distribution of electric current density may not be uniform. This is because the shape and size of the conductor can affect the flow of current.
What factors can affect electric current density in non-wire conductors?
The shape and size of the conductor, as well as the material it is made of, can affect the flow of electric current and therefore the current density. Additionally, the temperature and voltage of the conductor can also impact the current density.
How is the magnitude of electric current density calculated in non-wire conductors?
The magnitude of electric current density is calculated by dividing the current flowing through the conductor by its cross-sectional area. This gives the current density in amperes per square meter (A/m²).
Why is understanding electric current density important in non-wire conductors?
Understanding electric current density is important in non-wire conductors because it allows us to analyze and predict the behavior of the conductor. This information is crucial for designing and optimizing electrical circuits and systems.
  • Electromagnetism
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
  • Electromagnetism
