Deriving the equations of torque and ang. Momentum from Newton's laws
In summary: NET force acting on the center of mass, and the sum of all the internal force terms, which sum is ZERO by virtue of Newton's 3.law.Thus, we are left with: \sum_{i=1}^{N}\vec{F}_{e,i}=\sum_{i=1}^{N}m_{i}\vec{a}_{i}=\vec{F}_{net}, the external force acting on the center of mass.Dividing this sum with the total mass, we get Newton's 2.law for CENTER OF MASS motion.For the angular components, we multiply (2) with a unit vector in the direction of the angular
metalrose
113
I know what the definition of torque and angular momentum is.
But I read in a few books that
"Torque and angular momentum are not independent laws of nature, and have been derived from the more fundamental laws of Newton."
The above simply means, that the rotational motion is just a manifestation of Newton's laws at work.
How can we "derive" the concepts of torque and angular momentum by using just the Newton's three laws?
Another way to look at the problem:
Suppose we have an extended body, say a rod. Now I apply a force F at some point of this rod, apart from the center of mass. Let the rod's net mass be M. All the points on the rod, will then have an acceleration component in the direction of the force F, given by a=F/M.
But apart from this acc. component, all the points, except the C.O.M. have another additional component of acceleration, that is the angular acceleration.
My question is, Where did this angular acc. component come from? what caused it? (please don't give a lame answer like "torque of F caused it")
Please give your answer by using only Newton's laws and not torque or angular momentum.
According to the Newton's second law, the force F produces acc. a=F/M in all the points lying on the rod. But all the points(except c.o.m.) almost magically acquire another acc. component, i.e. the angular acc.
Please explain, how the Newton's laws, give rise to this extra angular acc. component.
Hi, metalrose!
Here's the explanation:
If you work with an spatially extended body, Newton's 2.law is valid for each individual segment, or element of the body.
Note a crucial feature here:
Each segment may perfectly well exert a force on its neighbouring element, which, in accordance with Newton's 3.law, exerts back an equal and opposite force on its neighbour.
Thus, if you then make the equation for the acceleration of the C.M, then all these internal forces will negate each other (virtue of the 3.law), and you have the resultant equation that says the acceleration of C.M is solely due the sum of EXTERNAL forces.
Your statement,
is utterly FALSE, the internal forces present may perfectly well give each ELEMENT of the rod a totally different acceleration than the acceleration the C.M has.
And when different elements of a body has different accelerations, then spatially, the body may undergo reconfigurations.
For RIGID bodies, the only types of such reconfigurations are ROTATIONS (whereas non-rigid bodies may undergo a lot of other types of reconfigurations besides)
@arildno
Thanks for the reply. I got the point.
Let me simplify the system. let's suppose we have a two particle system. Let's suppose the two particles are bonded to each other through a spring. As the spring constant of this spring tends to infinity, the system will tend to being a "rigid two particle body".
Now, we apply force F on one of these particles, perpendicular to the line joining the two points. How can we show that the two particle system will rotate along with accelerating forward, 'without using the concept of torque'. How can we show this by using only Newton's laws?
There are two forms of Newton's third law, a weak form and a strong form:
  • Weak form: The forces exerted by a pair of objects on each other are equal in magnitude and opposite in direction.
  • Strong form: The forces exerted by a pair of objects on each other are equal in magnitude and opposite in direction and lie along the line joining the two particles.
The weak form is sufficient to derive arildno's result, that the acceleration of the center of mass of a system of particles is the sum of the external force acting on the system of particles divided by the total mass of the system and to derive conservation of linear momentum. The strong form is needed to derive conservation of angular momentum.
I disagree with the statement "torque and angular momentum are not independent laws of nature, and have been derived from the more fundamental laws of Newton." To arrive at that statement one needs to endow Newton's laws for translational motion with a characteristic that has nothing to do with translational motion. There is no essential difference between the weak and strong forms of Newton's third law when it comes to translational motion.
Arildno mentioned the rigid body assumption. That assumption goes on top of Newton's laws, and it is useful for rotational behavior only. So once again we have a case where that statement in question is not true, strictly speaking.
Which is more basic, Newton's third law or the conservation laws, is quibbling with words. The weak form of Newton's third law can be derived from conservation of linear momentum, the strong form from conservation of linear and angular momentum. One last word: the conservation laws in turn derive from Noether's theorem, and that is a very deep result.
To take the case of the rod:
Let us divide the rod into N elements, 1,...N
Let [itex]\vec{F}_{e,i}[/itex] be the sums of external forces acting upon element (i), that is, the body producing that force (and hence recipient of element i's reaction force) is OUTSIDE the rod.
Let [itex]\vec{F}_{ij}[/itex] be an internal force, acting on element "i" from element "j".
With Newton's 3.law, we have:
[tex]\vec{F}_{ij}=-\vec{F}_{ji}[/tex]
Thus, for each element "i", we have Newton's 2.law:
[tex]\vec{F}_{e,i}+\sum_{j=1}^{N}\vec{F}_{ij}=m_{i}\vec{a}_{i}, \vec{F}_{ii}\equiv\vec{0}(1)[/tex]
The last requirement is just that "self-forces" (an element propelling itself) are zero/non-existent.
Now, let [itex]\vec{r}_{i}[/itex] be the position vector of element "i" with respect to some reference point, and let us take the cross-product with (1).
We get:
[tex]\vec{r}_{i}\times\vec{F}_{e,i}+\sum_{j=1}^{N}\vec{r}_{i}\times\vec{F}_{ij}=m_{i}\vec{r}_{i}\times\vec{a}_{i}(2)[/tex]
Now, if we are to add together all the N (2)-equations, we can pair our terms of internal forces like this:
[tex](\vec{r}_{i}-\vec{r}_{j})\times\vec{F}_{ij}[/tex], in concordance with Newton's 3.law of motion.
But, since we generally have, for the rigid bodies that forces act ALONG the direction between two elements, then it follows that the internal force is parallell to the relative position vetor between them, and thus that all these cross products disappear!
What we are left with is, on the left-hand side the sums of all torques of external forces, with respect to WHERE they actually act, and on the other side, an ugly inertia/acceleration-expression, which in the simple case of the rigid body that can be reduced to, effectively, the moment of inertia multiplied with the angular acceleration.
Note that you are assuming the strong form of Newton's third law here; you did not assume the strong form in deriving the behavior of the center of mass of the system. The strong form of Newton's 3rd is only needed for rotational behavior. In other words, rotational behavior represents something new on top of translational behavior.
Certainly.
That is why I invoke it only at a need-to-know basis! :approve:
I make it perfectly clear that we are dealing with the idealized case of the perfectly rigid body, i.e, a wholly mechanical system that behaves nicely with respect to conservation laws.
So does that then mean that rotational motion of an extended rigid body is NOT a manifestation of the Newton's laws? That rotational motion is JUST THERE, as a new law of nature?
And does that then mean that the equation T=r x F is an experimentally determined analogue, and can not be understood in terms of more fundamental laws?
It is quite difficult to chew the possibility that rotation is a totally different law of nature and has got no origins in the Newtons laws. It somehow, doesn't seem right, intuitively.
I somehow feel that when an extended body rotates, the origins of the angular accelerations lie in the complicated ways in which the internal forces act.
I always thought that the internal forces act in some complicated way, which then makes the body rotate. I was trying to analyze how rotation can come about by the way internal forces act.
No.
The rotational motion is generated by the presence of INTERNAL forces (as well as external forces), forces that do not affect the body's overall amount of energy&momentum.
Thus, whereas Newton's 2-law is valid for ALL systems, the torque-equations are only valid for a SPECIAL CLASS of such systems.
And therefore, due to lack of generality, they are slightly less "fundamental" than Newton's 2.law of motion.
In the mechanical way of thinking, that is.
If that is so, I am then looking for a step by step procedure for showing that this is so. How can we show, that rotational motion is nothing but a manifestation of the nweton's laws?
How can we show it for example in the two particle system I described in a reply before the above one?
Can you please analyze the two particle system whcih i described in a previous reply?
You would have solved my problem if you can do so...
Thanks..!
Well, I can certainly do so, but I want to give an example of a NON-rigid body, where it is actually easier to understand how the rotation comes about (DO remember, that the perfectly rigid body is an idealization!):
Now, suppose you have a rod I.
At its lower point, it is met by a force F, so that if its shape weren't to remain an I, it would look something like this: L (agreed??)
Now, to understand how rotation comes about in the real world, think of this I trying to resist to bend out of shape to an..L
How is that most easily done?
Simple! To become an \ rather than an I.
If you think of a minor displacement happening at the foot, the internal forces between that end, and the rest of the object will pull the rest of the object (rightwards&downwards), whereas the foot will be pulled (leftwards&upwards).
The shape gained by these force transfers is the \, rather than the L, due to the strength of the internal forces.
Other objects have less maximal internal forces, and will bend out of shape locally, rather than undergoing a bodywise rotation with overall shape preservation.
Is this understandable?
Presuming you understood the above post, let us focus on the problem you gave.
We have two balls B1 and B2, for simplicity with the same mass, m, connected by, for example, a massless, inflexible rod R of length 2l.
Let B1 be subject to some external force F, perpendicular to R.
In that case, we have Newton's 2.law:
For B1:
[tex]F+F_{12}=ma_{1}[/tex]
For B2:
[tex]-F_{12}=ma_{2}[/tex]
Do you see what our problem is here, with respect to the motions of B1 and B2?
We do NOT know what [itex]F_{12}[/itex] is!
Without further assumptions, or suppositions, we cannot proceed any further than deriving the acceleration of the C.M of the body, not the acceleration of the body parts!
So, how do we proceed then?
Do you agree that this is the crucial issue?
@arildno
Yes, this is precisely the issue, to determine the individual motions of B1 and B2 and using just the laws of Newton, show that B1 and B2 will rotate.
How do we do this?
metalrose said:
@arildno
How do we do this?
First off:
Did you understand post 11, in how a non-rigid object will locally deform, rather than undergoing bodywise rotation with shape preservation?
First off:
I had missed out your post 11. I have now read it. also, I understand the case of the non rigid body that you talked about.
But I think this doesn't have any bearing on the point of determining the individual motions of B1 and B2 and proving that they will rotate.
Oh, most definitely it has!
ALL objects are non-rigid, to some extent.
What happens in those bodies we call rigid, is that so strong INTERNAL STRESSES are set up in the WHOLE body as the result of just a tiny local deformation, that these internal stresses accelerate the rest of the body into the position of MINIMAL internal stress, and this is achieved by the motion we call rotational.
The I turns into an \, because the \-state is less stressful than the L-state.
(of course, the I-state itself is impossible to maintain, due to the presence of F).
Is this clear?
Now, to take a step further:
HOW are we to truly explain why rotation occurs?
It is important to understand what we're actually asking!
In the deepest sense, we are asking how are we to model the internal force F_12.
This is what we call the dynamical approach, i.e, force modelling on the local scale.
How this is done is to regard stiff and non-stiff objects as extremes on a spectrum of elasticity, springlike that is, where an "infinite" stiffness constant is the limiting case of the rigid body.
The theory in question is called "the theory of elasticity", and is a truly ugly monster of non-linear partial differential equations, and it CAN be shown from this that in the limiting case of the ideal, rigid body, shape-preserving rotation WILL occur.
Now, the more common approach, the one we learn in introductory mechanics courses, is the KINEMATIC approach, rather than the dynamic.
In the kinematic approach, we IMPOSE the condition of the perfectly rigid body, and this condition is nothing else than the imposition of constraints of MOTION, rather than modelling of FORCES.
This is what I was looking for. So that then finally means, that rotation CAN be understood as nothing but a manifestation of the Newton's laws.
And that the concepts of Torque are developed in an introductory mechanics course just because they are simple to work with, and are less rigorous, but are NOT the fundamental reasons for rotational motion, that rotational motion, in its deepest form, stems out from Newton's laws. Torques and similar concepts just serve as mathematical conveniences.
You talked about the dynamical approach. Where can I learn it from? I mean all about elasticity and the non linear p.d.e's and all? What level of physics course would include all of it? graduate?
And can any of the dynamical aspects be found in the hamiltonian and lagrangian mechanics?
Thanks!
Yes, as long as you accept that particular MODELLING OF FORCES is an empirical necessity that is not, all of its own, derivable from the "pure" Newtonian model.
How, for example, can we theoretically "derive" the gravitational force from F=ma?
That ain't possible..
We can use OBSERVATION, namely of accelerations, to deduce with the aid of Newton how the force "looks like". But that's another story..
To some extent, yes. In another way, the very concept of the torque introduces something independent from Newton's laws, namely that of a REFERENCE POINT, from which we see the motion of the object.
For example, how an object seem to rotate, or not rotate, from, say, a point moving about in an inertial frame is also given by the particular torque we're looking at.
We do NOT "need" to compute torques with respect to an object's C.M, any other point, inside the object or outside, moving or stationary, is equally acceptable reference points.
It is pretty heavy stuff.
Introductory courses will generally just concern itself with linear elasticity, you could look a bit here:
http://en.wikipedia.org/wiki/Linear_elasticity
I am but faintly acquainted to elasticity theory myself, and was introduced to it briefly as a parallell in fluid mechanics studies.
Thanks!
Certainly.
Variational techniques, that lie in the very heart of the hamiltonian formulation, is also heavily used in some elasticity studies, from what I know.
To give you a rough understanding of how a rotation ACTUALLY occurs in the rod, you should think in terms of a TRANSVERSAL WAVE, where the wavespeed is EXTREMELY FAST.
First the bottom end moves slightly, sending off a frantic message to the next segment to move also, this sending off a slightly less frantic message upwards the rod, and so on (SLIGHTLY less frantic, because the segment uses some of the imparted energy to move on its own!).
So:
The rod does NOT strictly move as a straight line segment, it just APPEARS to do so, due to the mind-boggling wave propagation speed!
It looks like a straight line moving, because the propagation speed is so much faster than the speed by which each segment perceptibly moves. Thus, the mysterious alignment of motion we call rotation happens because we don't see each element moving prior to the next element.
But, using the kinematic approach, we make a mathematical CONSTRUCT that capture most of those details of object motion we DO see...
PS:
Once the distribution of motion transversal to the rod has been set up, a freely rotating object will continue to be in a state of stress, namely that each element moves under a constant centripetal force provided by the rest of the rod, maintaining the rotation.
@arildno
I've thought about it in this way long before. There is a flaw with this, though I can't exactly remember it as of now, because I had figured it out way back, and am trying to recollect.
But anyways,
Is there absolutely no way, "using simple geometry and calculus" to show that my two particle system in which the spring constant , k, tends to infinity, will undergo a rotational motion?
Is there just no way to use simple math, and Newton's laws, and try to analyze how the system evolves in time after we have applied F on one of these particles, and finally show that the system rotates, much the same way, we analyze how a projectile will land, at what speed and angle and so on?
I tried to use simple math, and Newton's laws to analyze my two particle system, but I haven't been able to show that the motion will be a rotational one.
Well, if you ASSUME the body is perfectly rigid, then the acceleration distribution it can have is a provable fact.
Then, you don't need to do any force modelling it all, they will be determined by the body's imposed motion.
If you do NOT assume your body is perfectly rigid, but only an elastic body in the limit of rigidity, then you must start out with the theory governing non-rigid bodies.
You can't have it both ways, sorry about that! :smile:
I would prefer to work it out the second way, to work it out from the equations of non-rigid bodies and put the limit for rigidity and show that the body, in limit of rigidity will rotate.
And what all topics do I need to have covered in maths as well as physics to deal with the equations you mentioned?
thanks
What is torque and angular momentum?
Torque is the measure of the force that can cause an object to rotate around a fixed axis. Angular momentum is the measure of an object's rotational motion, taking into account its mass, velocity, and distance from the axis of rotation.
How are torque and angular momentum related to Newton's laws?
Torque and angular momentum can be derived from Newton's laws of motion, specifically the law of inertia and the law of conservation of momentum. These laws describe how forces act on objects and how they affect their motion.
What is the equation for torque?
The equation for torque is T = F * r * sin(θ), where T is torque, F is the force applied, r is the distance from the axis of rotation, and θ is the angle between the force and the lever arm.
What is the equation for angular momentum?
The equation for angular momentum is L = I * ω, where L is angular momentum, I is the moment of inertia, and ω is the angular velocity.
How can the equations for torque and angular momentum be applied in real-world situations?
The equations for torque and angular momentum can be used to analyze the motion of objects in rotational systems, such as wheels, gears, and pulleys. They are also essential in understanding the behavior of objects in space, such as planets and satellites.
  • Mechanics
  • Mechanics
