Problems on engineering mechanics
This discussion focuses on solving engineering mechanics problems from the textbook "Meriam." Key problems include calculating cone spacing for a slalom course with a maximum speed of 80 kph, determining total acceleration of a particle moving along a specific curve, deriving expressions for radial acceleration in a spiral path, and analyzing the gravitational attraction between two iron spheres. The answers provided include specific values and formulas necessary for understanding these mechanics concepts.
  • Understanding of kinematics and dynamics in engineering mechanics
  • Familiarity with calculus, particularly derivatives and integrals
  • Knowledge of gravitational forces and motion in physics
  • Ability to interpret and analyze curves and paths in mechanics
  • Study the principles of centripetal acceleration in vehicle dynamics
  • Learn about particle motion along parametric curves in physics
  • Explore the concepts of radial and tangential acceleration in circular motion
  • Investigate gravitational interactions and orbital mechanics in classical physics
Students of engineering mechanics, physics enthusiasts, and professionals involved in vehicle dynamics and gravitational studies will benefit from this discussion.
sage
these are a few problems from a book called meriam in which i(and some of my classmates) had got a bit stuck. some help will be welcome.
1) in a handling test, a car is driven through the slalom course shown. It is assumed that the car path is sinusoidal and that the maximum central acceleration is .7g. if the testers wish to design a slalom through which the maximum speed is 80 kph, what cone spacing L should be used? (L=46.1m)
2)a particle starts from rest at origin and moves along the positive brunch of the curve y=2*x^(2/3) so that the distance s from the origin along the curve varies with time according to s=2*t3; x,y,s are in inches, t in seconds . find the magnitude of total acceleration of the particle at t=1s?(ans:a=12.17 inch/s2)
3)A particle p moves along a path given by r=f(q) which is symmetrical about about the line q=0 where the radius of curvature of the path is r, the velocity of P is v. derive an expression for r’’ in terms of v,r, r, for the motion of the particle at this point. Ans: r’’= -v2(1/r- 1/r)
4) the particle p moves down the spiral path shown which is wrapped around the surface of a right circular cone of the base radius b and altitude h. the angle g between the tangent to the curve at any point is constant. Also, the motion of the particle is controlled so that q’ is constant. Determine the expression for the radial acceleration a(r) of the particle for any value of q. Ans: b*(q’)2 [(tan)2 g (sin)2b - 1]* exp[-q *tan g * sinb] where b= (tan)-1[b/n]
5) two iron spheres each of diameter 100mm are released from rest with a center to center distance of 1m . assume an environment in space with no forces except mutual gravitational attraction and calculate the time t required for the spheres to come in contact with each other and the absolute speed v of each sphere at the time of contact. Ans: t= 13 hours 33 minutes;
v= 4.76* 10-5 m/seconds.
question-how am i supposed to send the figures accompanying them? i have drawn them in word documents in my P.C. but can't get them pasted.
The interface may have changed in the intervening 18.5 years, but the method now is to use the pulldown that looks like a landscape.
  • · Replies 17 ·
