Understanding Internal & External Forces: Beginner's Guide
  • Thread starter Thread starter M@er
    Confused Forces
The discussion centers on the confusion surrounding the concepts of internal and external forces, particularly in the context of a car's braking system. It highlights that while brakes are an internal mechanism, the force that ultimately brings the car to a stop is friction, which is an external force acting on the tires. Participants clarify that the distinction between internal and external forces depends on the interaction context rather than physical location. The conversation also touches on the implications of braking on different surfaces, such as slippery roads, emphasizing that friction is crucial for deceleration. Overall, understanding these forces is essential for grasping how motion and stopping mechanisms work in physics.
M@er
Hey All,
This is my first post and I'm glad I joined. It looks like a lot of good advice is given around here. Anyway, on to my problem:
If only an external force can change the velocity of a body, how can the internal force of the brakes bring a car to rest.
This question totally stumps me. I'm not really sure what I am supposed to be doing at all. I am not sure exactly what forces are being taken into account, and I'm not sure what my answer is supposed to be. I'm pretty lost. I'm not necessarily looking for an answer, as much as I am looking for a little bit of explanation or clarification.
First of all, can you figure out what force causes the car to slow down?
If the road was very slippery and you hit the brakes, will the car slow down faster or slower when compared to a normal road?
M@er said:
Hey All,
I like that question. It raises a couple of other questions:
Internal to what? Are the brakes internal to the object they're acting on?
Once the brakes act on the tires, is the resulting interaction internal or external?
Edit: By the way, a better definition of internal and external is what the object interacts with, not its physical location. For example, electromagnetic torquing coils in a satellite might physically be located inside the satellite body, but they interact with the external magnetic field surrounding the Earth, making them an external actuator vs. an internal actuator.
well the car has many forces acting upon it, in all actuallity it is not the car that stops itself, it is the friction on the road. think of it like this, if the car was in space and breaked would it stop? no because the friction on the road stops it, and by external force they mean one that's not in the scope of the problem, such as a gust of wind, or a tennis ball that hits it, ect...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
