Proof that the speed of light is constant?
The discussion centers around the question of whether the speed of light is constant, particularly in relation to experiments like the Michelson-Morley interferometer and various claims about light's behavior in different media. Participants explore concepts related to special relativity, including time dilation and length contraction, while questioning the validity of certain experiments and interpretations.
  • Some participants assert that the Michelson-Morley experiment does not prove the constancy of the speed of light, suggesting that light traveling back on itself would cancel out effects due to Earth's rotation.
  • Others argue that the speed of light is a postulate of Special Relativity, verified through measurements rather than proven in a mathematical sense.
  • There are claims that scientists have stopped light and even accelerated it beyond the speed of light in certain media, raising questions about the immutability of the speed of light.
  • Some participants clarify that while light can travel at different speeds in various media, this does not contradict the principles of relativity.
  • Concerns are raised about the interpretation of experiments that suggest light can exceed the speed of light, emphasizing that these often refer to group velocity rather than the speed of individual photons.
  • There is a discussion about the implications of Maxwell's equations and the absence of an ether medium for electromagnetic wave propagation, questioning how one can differentiate between a moving and a stationary vacuum.
Participants express multiple competing views regarding the constancy of the speed of light, the interpretation of experimental results, and the implications of these findings. There is no consensus on the validity of the claims made about light's behavior in different contexts.
Participants highlight limitations in understanding the implications of various experiments, particularly regarding the definitions of speed in different media and the distinction between group and front velocities. The discussion remains open-ended with unresolved questions about the nature of light and its speed.
Phalanx
hey, I am looking for an experiment that prooves that the speed of light is constant as a preamble for a talk on the phenomena related to special relativity such as time dilation and length contraction.
As far as I can see many websites are claiming that the Michelson-Morley interferometer prooves that the speed of light is constant but as far as I can see this experiment doesn't work because the light traveling back on itself would cancel out any effect the rotation of the Earth would have. Even if this experiment does work, i do not understand how the speed of light must be constant just because there is no stationary ether.
Science news on Phys.org
Er.. be careful with the use of the word "proof". In mathematics, these are logical derivations at which you arrive. In physics, many of these things are postulates which are VERIFIED to be either valid or not. The constant speed of light is a postulate of Special Relativity, which are then verified either via measurements, or through the consequences of such a postulate. You don't "prove" it, you verify its validity.
Zz.
but.. it is not, Scientists have stopped light and even sped it up past c.
it might only be on a quantum level that those effects can be had, but it does show that c is not immutable... but then I guess you would have to ask if in those instances if it was just the frame of reference that the experiment had.
Substitute the word "supports" for "proves" and you'll make people here a lot happier. :smile:
As for experiments, take your pick:
List of experiments on speed of light
In a medium, yes, but not in a vacuum. The fact that light travels in different speeds in different media does not contradict relativity.
c is just saying it's constant, it doesn't say anything about the speed of the light.
but, does the fact that they were able to increase the speed of a photon past c show that the speed that light moves in a vacuum is not the maximum speed of particle sin the universe?
c simply states that light will remain at a constant speed unless slowed by a medium.
If they managed to make light faster than the "normal" speed at which it travels, what is used to fill "c" in e=mc^2, simply means that they either removed or replaced a medium. This doesn't contradict the fact that the speed of light is constant, it mearely backs up the fact that it will slow down in a median that is more dense than the previous...and vice-versa.
No such thing occurs. The NEC experiment of apparent superluminal signal does NOT violate the c limit. In fact, if you read the paper, no part of the pulse exceeded c. It is due to the pulse shapping due to the medium and thus, changing the group velocity of the pulse, NOT the photon.
Zz.
Stopping light is no big deal it happens all the time, OTOH you will need to post a link to experimental evidence of LIGHT traveling faster then c.
okay... well then what experiments support that the speed of light is constant? and can someone please explain to me how the michelen-morley interferometer works or direct me somewhere?
The people who ran the experiment are confusing things because when they say that they managed to get light to exceed c they don’t explain themselves properly.
Firstly when Relativity say light cannot travel faster than c it is really taking about information in light and not light.
In the experiments light manages to exceed c because their measurements are group velocity rather than front velocity. it is the front part of the wave which contains information, this part cannot exceed c ,the central fat part which dosent contain information and is basically pure light can exceed c if traveling through certain meduims like cesium , which is specially prepared for the experiment.
Not quite. Specially prepared Cesium can capture, then be triggered to emit a photon some time later. The speed of light is not, and has not been execeded.
Not in a vacuum no .
what i was trying to say just not very well, was that even though light did travel through the medium (cesium)faster than c,as it was traveling through cesium and not a vacuum and as the only important part in regards to the rules being violated is the part of the wave which contains the information the front of the wave and as that part didnt exceed the speed limit no rules were violated.
i think we can have a feel for why the speed of E&M propagation should be the same for all inertial reference frames. it really just comes from Maxwell's Eqs. and the knowledge that there is no ether medium that E&M is propagated in. i mean, how do we tell the difference between a moving vacuum and a stationary vacuum? if we can't, if there really is no difference between a moving vacuum and a stationary vacuum, that such a concept is really meaningless, then whether the light that you are measuring originated from a flashlight mounted on a rocket moving past you at [itex]c/2[/itex] or from a stationary flashlight, how does that change the fact that a changing E field is causing a changing B field which is causing a changing E field, etc.? that propagation of an E field and B field disturbance, which has velocity [itex]1/ \sqrt{ \epsilon_0 \mu_0 }[/itex]? how is it different?
whether you are holding the flashlight or moving past it at high velocity, Maxwell's Eqs. say the same thing regarding the nature of E&M in the vacuum. that is qualitatively different for waves that require a substantive medium to travel in, e.g. sound. if the wind is moving past you from left to right at 10 m/s, a measurement of the speed of sound coming from a source on your left will be 20 m/s faster than a sound emanating from a source on your right. but there is no (ether) wind for electromagneting radiation. so once the E&M wave has left its source, does it have any contact with it anymore? can it "remember" that it came from a high speed moving flashlight (relative to some observer) or a stationary flashlight? it can't. and if there is no "wind" to carry E&M, what would be left for it to know it should move any faster, just because its source was moving?
See the link that I posted in posting #4 in this thread.
Lets give this a go.
Do you accept e = mc2 to be true?
then c = [tex]^{+}_{-}[/tex][tex]\sqrt{e/m}[/tex] let's consider the + only.
c = [tex]\sqrt{e/m}[/tex]
Do you accept that the amount of energy associated with a specific mass is constant?
If so then e/m is constant, implying that c is constant.
Mauro.
Yes, C is constant. I'm not sure I see your point...
I think I see what he is saying, not that I'm well versed in this at all, please allow me to clarify:
c=+- e/m. (I'm going to guess we can throw out the negative...)
c=e/m?
So he is saying is there a specific amount of energy for any given amount of mass, regardless of whatever composes this mass? (ie, does a ton of feathers have the same energy as a ton of Uranium.) Because, the mass going into the energy, according to this, should be constant. I think. Mabye.
scientists have sped light past c?? how was that possible,, how could they see or record the results?
He was (I hope) referring to experiments done where light passes through a medium where the speed of light is (effectivly) smaller -and in some exotic media such as BE condensates MUCH smaller- than the speed of light in vacuum.
It is the NEC experiment from a while back on an anomalous medium that showed a group velocity faster than c. The unfortunate effect from this is that people only read the headlines, but not the details, which showed that no part of the wave went faster than c.
We need someone to volunteer to write a FAQ entry on this (the NEC expt and the apparent "faster than c" observation), since this has been asked quite often. Anyone interested? You may PM me if you wish.
Zz.
Mauro.
This is misleading, because it gives the implication that c can be DERIVED, which it can't. There are no first principle derivation for c, and you're welcome to scour all the literature available to satisfy yourself on this.
Zz.
Mauro.
what happens to the negative variable in the equation?
also is there any evidence that an object can travel faster than c?
  • · Replies 19 ·
13K
  • · Replies 51 ·
