Questions in regards to momentum
  • Thread starter Thread starter angel_romano
    Momentum
When throwing a ball horizontally while on roller skates, the action of throwing causes a backward motion due to momentum conservation. If the ball is held instead of thrown, the backward motion does not occur because no external force is applied. Firefighters face challenges when handling hoses that eject high-speed water, as the water's momentum can push them backward. The force exerted by the water is countered by the firefighter's grip and stance, which helps manage the recoil. Understanding these principles of momentum is crucial in both scenarios.
angel_romano
If you throw a ball horizontally while standing still on roller skates, you roll backwards. Will you roll backwards if you go through the motions of throwing the ball, but hold on to it instead?
And is it difficult for a fire fighter to hold a hose that ejects large amounts of high-speed water since it's momentum pushes the firefighter in the opposite direction, with the same momentum...or is it different?
For the first one, think about systems or just think about it O___O
For the second one, figure out what propels the water, etc.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
