How Does Trebuchet Arm Design Affect Moment of Inertia?
The forum discussion focuses on calculating the moment of inertia (MOI) of a trebuchet arm design for an AP Physics project. The setup involves a ball-bearing pivot, a string attached to a 500g cart, and a ramp to create angular acceleration. Participants emphasize the importance of measuring torque and angular acceleration to derive the MOI, suggesting that using a pendulum method could simplify the calculations. Additionally, they discuss various design considerations for the trebuchet arm, including drilling holes to reduce weight.
  • Understanding of moment of inertia and its calculation
  • Familiarity with torque and angular acceleration concepts
  • Basic knowledge of pendulum mechanics
  • Experience with experimental physics setups
  • Research the pendulum method for calculating moment of inertia
  • Learn about torque measurement techniques in physics experiments
  • Explore different materials and designs for optimizing trebuchet arm weight
  • Investigate angular acceleration calculations and their applications
Students in physics courses, educators teaching mechanics, and hobbyists interested in trebuchet design and performance optimization.
airforce840
For our AP Physics final project, we must do research on the moment of inertia ... which by that we are looking at a trebuchet's arm design, and also just trebuchet analysis(looking at the body of the trebuchet and how it will need to be for best performance with an arm of certain design).
We have an idea of how to test for the moment of inertia. Here is the set up.
The arm is on this ball bearing thing so that it can spin horizontally, a string is attached at where the axel will be, and pull system is attached to a ramp near by.. A 500g cart has the string attached to it so that when u let the car go... it slowly picks up in speed giving us an angular acceleration. We want to calculate that angular accell. and then use it to find the moment of inertia in that arm that will spin when the car moves down the ramp...
Any ideas? or is there any tips that someone can give us on how to better go about doing this? We have a little less than a month to get this done. We plan to make about 2-5 different arm designs. Also, if anyone knows a good way to make a trebuchet arm.. whether that being drill out holes in the middle or lighten it up in ways... any help is appreciated..if u need pictures of the set up.. i can have that arranged.
thanks in advanced..
-Connerville, Indiana's High School AP Physics Class :-p
It would help if you could post a drawing. I don't have a clear idea of the set up. But in order to calculate moment of inertia you have to measure torque and angular acceleration. I is, after all, the ratio of torque to angular acceleration - similar to mass = ratio of force to acceleration.
AM
Have you thought about simply using a pendulum to calculate the moments of inertia? Take a look at the attached PDF and perhaps a bit of googling will help. The method has been around for a lot of years. I have used it a couple of times to calculate the MOI of some complicated parts.
One thing as a note...if I remember correctly, the angular displacement has to be relatively small since there is a mathematical approximation involved that states that [tex]sin \theta = \theta[/tex]
15K
  • · Replies 20 ·
13K
  • · Replies 42 ·
