Calculating Velocity and Displacement in a Skateboarding Physics Experiment
The discussion focuses on calculating the velocity and displacement of a boy and girl on skateboards after they push off each other with a force of 30N for 1.2 seconds. The boy's mass is 45kg, resulting in an acceleration of approximately 0.6666 m/s², while the girl's mass is 40kg, leading to an acceleration of about 0.75 m/s². The calculated velocities after pushing are 0.79 m/s for the boy and 0.9 m/s for the girl, with the girl's displacement during the push calculated at 0.54 meters. Participants suggest using the impulse/momentum theorem for a more straightforward calculation and emphasize considering the movement of their center of masses. The calculations and suggestions are generally affirmed as correct and helpful.
MetalCut
I just want to know if this is correct.
The question is:
A boy and a girl on a skateboard push each other away at 30N for 1.2 s
The boys' mass is 45kg and the girl's mass is 40kg.
Determine the velocity after they have stopped pushing each other?
How far did the girl move while their hands were touching?
BOY Girl
F=30N F=30N
m=45kg m=40kg
a=0.6666m/s/s a=0.75m/s/s
Now to get the velocity, do i use v=v0+at, I am not sure.
So for the boy then v=0+(0.66666)(1.2)
v=0.79m/s
And for the girl then v=0+(0.75)(1.2)
v=0.9m/s
And for the displacement of the girl: = v0t+(0.5)(0.75)(1.2)^2
= 0.54m
The question is:
BOY Girl
F=30N F=30N
m=45kg m=40kg
v=0.79m/s
v=0.9m/s
= 0.54m
Looks good to me:smile:
Thanx man.
I appreciate.
Looks OK to me. An easier way to find the velocities after they stop pushing is to use the impulse/momentum theorem. (Look it up.)
Also, realize that we are talking about the movement of their center of masses. (The boy and girl are deformable objects.)
Thanx man. I will do that.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
