Proving the Limit of e^x as x --> 1 using Epsilon-Delta Method
  • Context: Graduate
  • Thread starter Thread starter mannyfold
    Limit Proof
The discussion revolves around proving the limit of e^x as x approaches 1 using the epsilon-delta method. Participants explore various definitions of e and the properties of exponential and logarithmic functions, while attempting to construct a valid epsilon-delta proof.
  • One participant requests a proof of the limit of e^x as x approaches 1 using the epsilon-delta method, indicating it is for review rather than homework.
  • Another participant discusses different definitions of e, including sequences and integrals, emphasizing the continuity of e^x.
  • A participant expresses frustration over the need for precise definitions, arguing that simply stating e as 2.718... is insufficient for a rigorous proof.
  • One participant provides a structured approach to the epsilon-delta proof, deriving bounds for x based on the properties of logarithmic and exponential functions.
  • Several participants highlight the necessity of defining e and logarithmic functions rigorously to validate the proof, questioning the implications of using informal definitions.
  • There is a discussion about the assumptions made in the proof regarding the continuity and properties of logarithmic and exponential functions.
  • Some participants agree on the importance of definitions but differ on the implications of using informal versus formal definitions in the context of the proof.
Participants generally agree on the importance of definitions in proving the limit, but there is disagreement on the adequacy of informal definitions and the assumptions made in the proof. The discussion remains unresolved regarding the best approach to rigorously prove the limit using the epsilon-delta method.
Limitations include the lack of consensus on the definitions of e and logarithmic functions, as well as the assumptions made regarding their properties. The discussion reflects varying levels of understanding of mathematical rigor and proof techniques.
mannyfold
Can anyone prove that the limit of e^x as x --> 1 is e using the epsilon-delta method?
This is not a homework problem, but I am trying to review my course in analysis from a few years back, and this one has me stumped.
Exactly how are you defining ex? One standard way is to define an, for n a positive integer, as [itex]a\ddot a\cdot\cdot\cdot a[/itex] n times. Then a0= 1 follows from an+ m= anam, a-n= 1/an follows from the same, [itex]a^{\frac{1}{n}}= ^n/sqrt{a}[/itex], [itex]a^{\frac{m}{n}}= ^n\sqrt{a^m}[/itex] which give ar for r any rational number. To define ax for x an arbitrary real number, we take a sequence of rational numbers {rn} that converges to x and define [itex]a^x= \lim_{n\leftarrow \infty}a^{r_n}[/itex]. Of course, that defines ax to be continuous for all x so ex goes to e as x goes to 1 by continuity.
Another method is to define [itex]ln(x)= \int_0^x \frac{1}{x}dx[/itex] and then define ex to be the inverse function to ln(x). Of course, since ln(x) is defined as an integral, it is continuous and so is its inverse. That is, ex is continuous by definition and again ex goes to e as x goes to 1 by continuity.
I'm simply using e = 2.718... and raising it to x, nothing fancy about it. I'm looking for the trick that will give me delta in terms of epsilon (the epsilon-delta proof) or somehow to put a bound on delta.
Unfortunately, for this, I'm not at liberty to make definitions. It's not merely proving the limit, but utilizing the epsilon-delta approach. Thanks, though.
(I'm preparing for an entrance exam.)
what are the rest of your decimals? unlkess you tell us exactly what number e is, you cannot prove that e^x really approaches e as x goes to 1 by your method. and unless you define precisely what e^x means you also cannot do it.
the easiest way is halls second method that e^x is continuous, since it is the inverse of the continuous function ln(x), hence it suffices to show e^1 = e, but that follows from the fact that e is defined as the unique number such that ln(e) = 1.
I didn't say you should "make" definitions but you certainly have to use definitions in order to prove anything. Saying "I'm simply using e = 2.718... and raising it to x, nothing fancy about it." makes no sense. That's extremely "fancy"! Raising an irrational number to an irrational power requires using limits itself. You will have to at least state a precise definition for "using e = 2.718... and raising it to x".
If this is a specific question on a practice exam, please state the complete problem itself.
Let [tex]\epsilon[/tex] be a small positive real number. We have to prove that there exists a correspondent [tex]\delta[/tex] such as
[itex]| e^x - e | < \epsilon[/itex] for all [itex]1-\delta < x < 1+\delta[/itex] and [itex]x \neq 1[/itex].
We have
[tex]| e^x - e | < \epsilon \Rightarrow -\epsilon < e^x - e < \epsilon \Rightarrow e - \epsilon < e^x < e + \epsilon \Rightarrow \ln (e-\epsilon) < x < \ln(e + \epsilon) \Rightarrow 1- \ln \frac{1}{1-\epsilon / e} < x < 1 + \ln (1+\epsilon/ e)[/tex]
(we have used the fact that exponential an logarithmic functions are increasing in their domain).
Now, by noting that
[tex]\ln(1 + \epsilon/ e) < \ln \frac{1}{1-\epsilon /e}[/tex]
we can choose [itex]\delta = \ln (1 + \epsilon / e)[/itex] which satisfies our initial request.
Gee, I didn't think that defining e was such a priority. I simply meant that e is the irrational number that serves as the base of the natural log, and as such, it can't be stated as a number with a definite number of decimal places (it is like PI in this regard).
Thanks, WigneRacah, you hit the nail right on the head!
i agree the argument just given is nice and simple, but it proceeds bya ssuming all the thigns that have been pointed out as necessary. the hard part is to prove that log and exp do have the properties that were just assumed, using suitable definitions.
the argument just given is the trivial observation that if f and g are mutually inverse continuous, hence monotone (e.g. increasing) functions, then f maps the interval (a-e,a+e) to the interval (f(a)-d1,f(a)+d2) if and only if d1 = f(a) - f(a-e), and d2 = f(a+e) - f(a).
for instance, without a definition of log or of e, yopu have no idea what the number delta is that you have been given here, i.e. how can you say that delta must be ln(1 + epsilon/e) when you say you don't need a definition of e? if you don't know what e is then you don't know what ln(1 + epsilon/e) is either.
do you see? you are sort of asking for an answer that will look ok, on a test but without understanding what any of the letters mean in your answer. this is not your fault, as you seem not to have had any instruction in mathematical thinking or proof. the idea is to ask yourself what the symbols mean in your statements.
It's not in this case, since [itex]\lim_{x \rightarrow 1}a^x = a[/itex] [itex]\forall a \in \mathbb{C}[/itex] (using usual definitions). As Halls pointed out, you do need a rigorous definition for exponentiation of a real number by a real exponent, and of what a logarithm is, in order to do your problem.
Yes, but you have to understand that that's not a definition. Neither is "e = 2.712818..." because there are infinitely many numbers I can write that way. A common definition for [itex]e[/itex] is
[tex]e = \lim_{n \rightarrow \infty}\left(1+\frac{1}{n}\right)^n,[/tex]
for example (you have to prove that the limit exists in order for this to make sense, of course). There are many other possibilities.
  • · Replies 20 ·
  • · Replies 25 ·
