Register to reply
Help with Stoichiometry and Volumetric Analysis
Share this thread:
kara
#1
Oct13-06, 05:06 PM
P: 54
I need some help with this question.
A piece of chalk (mainly calcium carbonate) is placed in 250 mL of 0.293 M HCl. All the CaCO3 reacts, realising CO2 gas, and leaving a clear solution. 50.00 mL of the solution is pipetted into another flask. 87.1 mL of 0.0567 M NaOH is required to titrate the HCl remaining in this 50.00 mL portion. What was the original mass of CaCo3 in the piece of chalk?
So far i've found balanced chemical equations from the question... they are:
1. CaCO3 + 2HCl --> CaCl2 + CO2 + H2O
2. HCl + NaOH --> NaCl + H2O
Where should i go from there, the info given is really overwhelming.
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
GCT
#2
Oct14-06, 05:14 PM
Sci Advisor
HW Helper
GCT's Avatar
P: 1,769
You should be able to determine the moles of HCl that had reacted with the CaCO3, to do this you need to know the original, total, moles of HCl and the amount that remained after the reaction with CaCO3.
Register to reply
Related Discussions
Experiment Volumetric analysis - Acid base Biology, Chemistry & Other Homework 1
Chemistry - Volumetric Analysis I can't do this Biology, Chemistry & Other Homework 3
Volumetric Analysis Chemistry 1
Help A Car Guy Out (Volumetric Efficiency) General Physics 9
Volumetric analysis question. Help Chemistry 7
