Method of consistant deformations
  • Thread starter Thread starter jmf322
    Method
The discussion focuses on analyzing an indeterminate structure with a degree of indeterminacy of 2, involving a frame with two spring supports and a fixed support. The user seeks to confirm that each spring contributes only one degree of indeterminacy, with one spring allowing vertical movement and the other horizontal. There is concern about whether the springs might introduce additional redundancies due to their differing stiffness units. The user is proceeding with three primary structures and two compatibility equations to address the degrees of indeterminacy. A visual representation of the structure is anticipated to clarify the analysis further.
jmf322
I am analyzing an indeterminate structure with a degree of indeterminacy of 2(i think).
It is a frame with two spring supports and a fixed support. (and external loadings). I am required to use method of consistant deformations.
My question is about the springs. I would like to verify they contribute only one degree of indeterminacy each. One is in the vertical(moves up and down) and the other is horizontal(moves left and right). They are attached to the same joint.
So I am assuming three primary structures: Externally loaded structure, redundant as a unit force in the vertical, and redundant as a unit force in the horizontal.
I've noticed that the horizontal-spring stiffness has units (Force*Length)/radians, and the vertical-spring stiffness has units Force/Length.
My main concern is there may be a greater degree of indeterminacy i am not taking into account? :confused: Do these springs contribute more redundants than I am assuming? :confused: I hope I have been specific enough without a picture of the structure.
According to what you've described, the system should have a degree of indeterminacy equal 2, as you said.
I would like to see a picture anyway.
radou - thanks for the quick reply, i am attempting the problem with three primary structures and two compatability equations(two degrees of indeterminacy)
cyclovenom - i'll post a picture shortly.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
