Deriving laplacian in spherical coordinates
mooshasta
Hey...
Could someone help me out with deriving the LaPlacian in spherical coordinates? I tried using the chain rule but it just isn't working out well.. any sort of hint would be appriciated. :)
\nabla^2 = \frac{1}{r^2} [ \frac{\partial}{\partial r} ( r^2 \frac{\partial}{\partial r} ) + \frac{1}{\sin \theta} \frac{\partial}{\partial \theta} ( \sin \theta \frac{\partial}{\partial \theta\ ) + \frac{1}{\sin^2 \theta} \frac{\partial^2}{\partial \phi^2} ]
I want to understand the derivation too. I understand the gradient in spherical coordinate, but the divergence formula bothers me. I got some info from some website saying that one can find a basis of vectors where its divergence is zero then take the divergence of the function based on those vectors...
If anyone was curious about this, I found the solution online:
http://planetmath.org/encyclopedia/%3Chttp://planetmath.org/?method=l2h&from=collab&id=76&op=getobj
That's one way of doing it.
Here's another one:
\vec{i}_{r}=\sin\phi\cos\theta\vec{i}+\sin\phi\sin\theta\vec{j}+\cos\phi\vec{k}, \vec{i}_\phi}=\frac{\partial\vec{i}_{r}}{\partial\phi}=\cos\phi\cos\theta\vec{i}+\cos\phi\sin\theta\vec{j}-\sin\phi\vec{k},\vec{i}_{\theta}=\frac{1}{\sin\phi}\frac{\partial\vec{i}_{r}}{\partial\theta}=-\sin\theta\vec{i}+\cos\theta\vec{j}
along with:
\frac{\partial\vec{i}_{r}}{\partial{r}}=\frac{\partial\vec{i}_{\phi}}{\partial{r}}=\frac{\partial\vec{i}_{\theta}}{\partial{r}}=\vec{0}
\frac{\partial\vec{i}_{\theta}}{\partial\phi}=\vec{0},\frac{\partial\vec{i}_{\phi}}{\partial\phi}=-\vec{i}_{r}
\frac{\partial\vec{i}_{\phi}}{\partial\theta}=\cos\phi\vec{i}_{\theta},\frac{\partial\vec{i}_{\theta}}{\partial\theta}=-\sin\phi\vec{i}_{r}-\cos\phi\vec{i}_{\phi}
Now, given these relations, along with the expression for the gradient in spherical coordinates \nabla=\vec{i}_{r}\frac{\partial}{\partial{r}}+\vec{i}_{\phi}\frac{1}{r}\frac{\partial}{\partial\phi}+\vec{i}_{\theta}\frac{1}{r\sin\phi}\frac{\partial}{\partial\theta}, we may easily derive the expression for the Laplacian by differentiating, and performing the dot products:
\nabla^{2}=\nabla\cdot\nabla=\vec{i}_{r}\cdot\frac{\partial\nabla}{\partial{r}}+\frac{1}{r}\vec{i}_{\phi}\cdot\frac{\partial\nabla}{\partial\phi}+\frac{1}{r\sin\phi}\vec{i}_{\theta}\cdot\frac{\partial\nabla}{\partial\theta}
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
