Thread Closed
Spring hinges..???
Share Thread Thread Tools
Nov28-06, 02:06 PM   #1
Spring hinges..???
I need a spring type hing to do a particular job. From a closed position when in use it can be pulled open to 90 degrees and locks in position. Then can be released to spring back to closed position? Also could one open to 180 degrees?....is this possible?
thanks
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
Nov28-06, 02:36 PM   #2
Recognitions:
Gold Membership Gold Member
It's all possible. What's your application? What loads do they need to take? Are you designing them or specifying them? Are you buying large quantities? What other constraints are on your selection?
Nov28-06, 02:44 PM   #3
Mentor
I did a google search, and ended up at this patent:
http://patft.uspto.gov/netacgi/nph-P...&RS=PN/4524486
Sounds like it would be useful to see the drawings, but for some reason the Images section of this patent aren't displaying correctly. Maybe see if you can get a copy of it or the other patents it references.
Nov28-06, 03:18 PM   #4
Recognitions:
Spring hinges..???
Another consideration is how you want the locking mechanism to work, especially what sort of release sequence you want. (Just apply extra force, or have to manually pull some sort of trip system?)
I've seen hinges that almost defy imagination; you can get them to do just about anything. Some will open to over 360 degrees, although they are pretty much limited in applications.
Thread Closed
Thread Tools
Similar Threads for: Spring hinges..???
Thread Forum Replies
Vertical forces on door hinges Introductory Physics Homework 1
Forces on Hinges Introductory Physics Homework 3
Tension/Hinges Introductory Physics Homework 7
Torque and Door Hinges Introductory Physics Homework 1
force on door from two hinges - easy - help anyone? Introductory Physics Homework 4
