Understanding Resistance and Phasors for Non-Electrical Engineers
  • Thread starter Thread starter girls4engineers
    Phasors Resistance
Bilateral resistance refers to resistors with symmetrical characteristic curves, such as ohmic resistors, while unilateral resistance, like that of diodes, does not exhibit this symmetry. Understanding phasors and sinusoidal quantities is crucial for grasping AC circuit behavior, with resources like Wikipedia and dedicated AC theory websites being recommended for further study. The relationship between voltage and current in resistors is defined by their characteristics, which can vary among different types of resistors. Clarifying these concepts is essential for mechanical engineers venturing into electrical engineering. Mastery of these topics will enhance comprehension of electrical systems.
girls4engineers
Resistance and Phasors?
Hi I am a Mechanical engineer but I am taking a module in electrical, which isn't my strong point. Please can someone explain the differnce between bilateral and unilateral resistance and what is a good website to help me understand phasors and sinusoidal quantities.
Thanks x
Probably wikipedia.org has some info on phasors. I'm not familiar with the terms bilateral and unilateral resistance. Can you provide some context for those terms?
Here's a good website for AC theory: http://www.ibiblio.org/obp/electricCircuits/AC/index.html
You can define a resistor as a device in which voltage and current are related to each other at any instant. The relationship is called the characteristic of the resistor.
By this definition, an ohmic resistor, a diode or a voltage source can all be considered resistors.
A bilateral resistor is one whose characteristic curve is symmetrical in relation to the origin. An ohmic resistor is bilateral, a diode is not.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
