Electricity Circles question that's killing me
  • Thread starter Thread starter Dragons Master
    Circles Electricity
The discussion centers on understanding potential difference in a series circuit, specifically addressing a problem involving points P and Q. The potential at point P is given as 200 volts, and the potential difference between P and Q is calculated to be 110 volts. Using Ohm's Law (V=IR), the resistance is determined to be 5.5 ohms, leading to the conclusion that the potential at point Q is 110 volts. The correct potential at Q is confirmed to be 90 volts after correcting the initial calculations.
  • Understanding of series circuits and their characteristics
  • Knowledge of potential difference in electrical circuits
  • Proficiency in applying Ohm's Law (V=IR)
  • Basic familiarity with electrical units such as volts, amperes, and ohms
  • Study the principles of series and parallel circuits
  • Learn about potential difference and its calculation in electrical circuits
  • Explore advanced applications of Ohm's Law in circuit analysis
  • Investigate common mistakes in electrical calculations and how to avoid them
Students studying electrical engineering, educators teaching circuit theory, and anyone preparing for tests involving electrical concepts and calculations.
Dragons Master
Heya Folks,
First I would like to apologize for my bad English - I live in Israel and our mother toungue is Hebrew here, I'll try my best though..
Now I don't know how you call what we call Straght-Line Electricity Circles but basically I mean AC just not alternative ;)
Anyways my problem is with the following circle:
http://dgemu.suhost.com/physicu/1.gif
(the url is http://dgemu.suhost.com/physicu/1.gif if you don't see it good).
I'm told that the potential in P is 200 volt and I'm asked what's the potential in Q.
Now I went by the (using $ as sigma):
$E = $I*R
equation and I found that I is 20A, and then I found out that the potential from P to Q is 110v so I assume the potential in P is 310v - but that answer is wrong..
I'm doing an online test and I only get TrUE of FALSE for my answers and I have no idea what is the correct question and how to get to it.
Any help would be appreciated,
- Ben
nvm I guess that was really stupid I should've done -110 and then it's 90 and not 310 - the correct answer is 90 - thanks for anyone who read this topic..
Hi Ben,
Thank you for reaching out with your question. It seems like you are struggling with understanding electricity circuits and potential difference. I will do my best to explain it to you.
First, in English we call "Straght-Line Electricity Circles" a series circuit or a circuit with only one path for the electricity to flow. This is different from a parallel circuit where there are multiple paths for the electricity to flow.
Now, to solve your problem, we need to understand the concept of potential difference. Potential difference is the difference in electric potential between two points in a circuit. In your circuit, the potential difference between P and Q is 110 volts.
To find the potential at Q, we need to use Ohm's Law: V=IR, where V is voltage, I is current, and R is resistance. In this case, we know the potential difference (V=110V) and the current (I=20A), so we can rearrange the equation to solve for resistance (R).
R=V/I = 110V/20A = 5.5 ohms
Now that we know the resistance, we can use Ohm's Law again to find the potential at Q.
V=IR = 20A*5.5 ohms = 110V
Therefore, the potential at Q is also 110 volts.
I hope this helps you solve your problem. Just remember to use Ohm's Law and understand the concept of potential difference. Good luck on your online test!
  • · Replies 23 ·
  • · Replies 105 ·
  • · Replies 16 ·
