| Thread Closed |
Why not crushed by air? |
Share Thread | Thread Tools |
| Jan9-07, 06:45 PM | #1 |
It has been estimated that the mass of nitrogen alone in the column of atomsphere above each square metre of the Earth's surface amounts to about 8 tonnes. Why aren't we crushed by this? 2. Relevant equations none 3. The attempt at a solution Air in the atomsphere is not just nitrogen and they are dense as the question suggested. Are we are not crushed by them essentially because of Newton's third law? We are surrounded by dense air in ground level. What kind of molcules are they? They surround us and collide with our bodies and make us not as cold if without them. The different densities of air all exert forces to the next layer and due to the third law there is an upward force from the succeeding layers. These layers does the same and you get somewhat of a cancellation of forces on each layer. Hence equilibrium is reached for each layer as there is no net force and we are not crushed by the upper level air. So a cushioning effect is passed down through the layers. The image tries to illustrate this. |
| Jan9-07, 06:52 PM | #2 |
We can't be crushed by earth's atmosphere because air spreads out equally. The only way you could be crushed by air is if you were in a tank and someone kept pumping in air.
| Jan9-07, 07:13 PM | #3 |
The air pressure at the surface of the earth is 14.7 psi. This force does not act in a single direction (downwards) -- it acts in all directions. In other words, the air pushes on your left side with the same force that it pushes on your right side. The force is balanced on both sides, so you don't go sliding sideways. The same is true of the forces in any two directions, including up and down.
This is easily understood when you realize that pressure is caused by molecules of air moving in all directions, randomly, imparting forces upon things they strike from any direction. Water is essentially imcompressible, meaning that it does not change volume much with changing pressure. Thus, we stay the same size even when the air pressure changes due to weather or when we walk up hills. - Warren |
| Jan9-07, 08:31 PM | #4 |
| Jan9-07, 08:33 PM | #5 |
The net force due to the air pressure is zero, because the air pushes on you from every direction. I cannot understand your 'cushioning' concept, but I can tell you immediately that it's not useful.
- Warren |
| Jan9-07, 08:34 PM | #6 |
Have you ever tried to suck all the air out of a plastic coke bottle? Yup, it gets crushed. Our bodies would too if we weren't filled with air and liquid.
| Jan9-07, 08:39 PM | #7 |
| Jan9-07, 08:42 PM | #8 |
No. No offense, but your notion is nonsense. We understand gas very well via a theory known as statistical mechanics, which is derived immediately from Newton's laws of motion. The reason the gas doesn't all come down at once is:
Thermal energy The individual gas particles have thermal energy, and move about randomly. They rise and fall in ballistic trajectories, just like baseballs (except there are many, many collisions). - Warren |
| Jan9-07, 10:06 PM | #9 |
Is that the reason why some bollons rise but some don't. The ones that do are filled mostly with hydrogen. As for the original question, the answers in the book suggested: "While the atmosphere exerts a pressure on us, we exert an equal pressure back." The pressure on us must be very small because the effect of gravity is tiny. The overriding force are random forces due to thermal motion as you say. That is why they don't crush us because it's also good that they don't escape into space as would be predicted without gravity. |
| Jan10-07, 01:03 PM | #10 |
| Jan10-07, 02:19 PM | #11 |
Mentor
| Jan10-07, 05:17 PM | #12 |
But imagine a person standing on the ground. He is more exposed to air on top of him than from below him so there is a net force downwards from the atomsphere? And if you factor in gravity than that is another tiny bit more net force directed towards your feet. |
| Jan10-07, 07:26 PM | #13 |
Mentor
Further, air pressure is not zero! Note that the orientation of the suction cup and surface is irrelevant: the surface can be horizontal, vertical, sideways, upside down--it doesn't matter. Air pressure acts in all directions. |
| Jan10-07, 09:29 PM | #14 |
Or are you saying even though if you add all the forces up, it equals 0, the area these forces act on may not be equal. i.e. There are two forces 8N and -8N. The 8N force act on 2m^2 of the surface only whereas the -8N force act on 3m^2 of the surface only. In this way net pressure is nonzero. But the mouse could also get completely crushed even if total force and pressure on it is 0. i.e. there could be opposite force and pressure (hence net 0) on top of it and from the bottom. The top exerted by the elephant and the bottom by the ground. |
| Jan10-07, 10:54 PM | #15 |
Note: If the edges of the soles of your shoes make airtight seals with the floor below them, then there will be a net downward force (because there's no air below your feet) of about 1000-2000lbs. |
| Jan10-07, 11:53 PM | #16 |
| Jan10-07, 11:56 PM | #17 |
[tex]P = \frac{\vec{F} \cdot \vec{A}}{|A|^2} [/tex] Also, if these quantites change over the scale of the object of interest, you will have to take elemental areas and then integrate over the entire object. Perhaps a better way of writing this would be: [tex]\vec{dF}=P~\vec{dA} [/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why not crushed by air?
| ZapperZ must be crushed... | General Discussion | 7 | ||
| Can the insurgency be crushed? | Current Events | 66 | ||
