What Happens When a Transmission Line Source is Switched Off?
When a transmission line source is switched off, it is crucial to differentiate between creating an open circuit and effectively shorting the source. The discussion highlights that turning off the source voltage is akin to setting the voltage across it to zero, resembling a short circuit rather than an open circuit. The calculations presented for voltage across the load resistor need to account for the actual behavior of the circuit when the source is deactivated. Clarification is needed on whether the source is simply disconnected or if it is actively shorted. Understanding these nuances is essential for accurately analyzing the system's response.
seang
I'm looking at a lossless transmission line where the load is a resistor, and the input is a step. The source resistance is zero, and the system has reached steady state.
So in this case, what happens when the source is switched off? You'd have the resistor on the right, and to the left of the t-line, an open circuit. Isn't this the same as a source resistance of infinity?
So to obtain the initial, positive direction voltage, I'd say:
V = (V(steady) * R (characteristic) / (R (source) + R (characteristic))
<br /> V^+ = \frac{V_o * R_0}{R_s + R_0}<br />
which equals 0. I doubt this is correct, but I don't know what I'm doing wrong.
Could I maybe?
<br /> V^+ = \frac{V_o * R_0}{R_L + R_0}<br />
This is a hard question, at least as stated. Are you saying that the IC is that there is a Vo source with Rs=0, the system is settled, and then you open circuit the source?
Yes sir. I think anyway. I'll attach some pictures later today
If you switch off the source at t=0, the result is not an open circuit: it is a short circuit! Turning off the source voltage is equivalent to setting the voltage across it to zero, which is the same as a short circuit. If you'd like, you can think about it as adding another voltage signal opposite to the original one.
I think you're incorrect. The source is 'turned off' via a switch, which forms the open circuit right? The source doesn't go to zero; I think that's what you had in mind.
Well, as Manchot says, turning off a real power supply and leaving it connected does ramp the output voltage down to zero (slowly usually because of all the output capacitance in the power supply). On the other hand, you can open circuit the connection between the power supply and the transmission line with an in-line switch. It's important to define exactly what you are doing in this problem.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
