Rocket with Variable Mass and Air Resistance.
The discussion focuses on calculating the terminal velocity of a rocket with variable mass and linear air resistance. The rocket's parameters include a mass of 1000 kg, fuel mass of 10000 kg, fuel burn rate of 100 kg/sec, and exhaust velocity of 3000 m/sec, with a constant gravitational force of 9.8 m/sec² and air resistance coefficient k set at 0.1 n-sec/m. The differential equation derived for the rocket's motion is mdv/dt = 100Ve - mg - kV, which simplifies to dv/dt + kV/m = (100Ve/m - g). The integration of this equation is essential for determining the terminal velocity when the fuel is exhausted.
  • Understanding of differential equations, specifically first-order linear differential equations.
  • Familiarity with the principles of conservation of momentum in variable mass systems.
  • Knowledge of basic physics concepts such as gravity and air resistance.
  • Experience with integration techniques in calculus.
  • Study the integration techniques for first-order linear differential equations.
  • Learn about the effects of air resistance on projectile motion and terminal velocity.
  • Explore advanced topics in rocket propulsion and variable mass dynamics.
  • Review conservation laws in physics, particularly in systems with changing mass.
Physics students, aerospace engineers, and anyone interested in rocket dynamics and the effects of air resistance on motion.
holdenthefuries
Problem:
A rocket is launched vertically upward. The rocket has a mass Mr and carries Mo of fuel. The fuel burns at a constant rate (ß) and leaves the rocket at speed Ve relative to the rocket. Assume constant gravity (9.8m/sec^2). There is an air resistance given by F(a) = -kV.
Where V is the velocity of the rocket.
Take:
k = .1 n-sec/m
ß = 100 kg/sec
Mr = 1000 kg
Mo = 10000 kg
Ve = 3000 m/sec
What is the terminal velocity of the rocket (the velocity when fuel runs out)?
-----The general solution for this problem is an extension of conservation of momentum for a system of variable mass.
mdv/dt = ∑F(ext) + Vrel(dM/dt)
I have no problem when the external force is solely gravity, however, when this problem presents linear air resistance, I am running into a bit of trouble with the integration.
My setup of the differential equation is as follows:Set dm/dt to constant. dM/dt = ß = 100 kg/sec.
I am attempting to integrate the velocity from V(0) to V(Terminal), and the time from t=0 to t=t(final)= Mo/ß = 10000/100 = 100 seconds.
My question is regarding the velocity portion of the differential equation.
I can't seem to get that V over to the left side of the integral by itself... and I'm wondering if I could get some sort of example on how to do that type of integration, or if I've gone astray somewhere.
Does this integration qualify as a first order differential?
i.e.
dy/dx + P(x)y = Q(x) ?Addendum:
Okay, so I've set up the equation:
m/k(100Ve/m-g) - (m/k(100Ve/m-g)e^(-kt/m))
Thanks!
Sean
Yeah, it does. The solution's [tex]ye^{\int p(x)}=\int Q(x)e^{\int P(x)}dx[/tex]
Tips for making this easier:
Remember that ultimately the mass is constant (since the M comes from the force being applied) and don't try and trick yourself into thinking that it is a variable in the end.
In a rocket formula with linear air resistance, it is helpful to compare your answer to something you'd expect without air resistance.
  • · Replies 47 ·
  • · Replies 42 ·
  • · Replies 16 ·
