How many moles are in 100 grams of sodium chloride (NaCl)?
  • Chemistry
  • Thread starter Caitex3
  • Tags
    Moles
In summary, the conversation is about determining the mass of one mole of different substances, calculating the number of moles in a given mass, and converting between moles and particles. The molecular mass is used to calculate the number of moles, and there are 6.02*10^23 atoms in one mole.
Caitex3
1. :confused: :confused: :confused:
i tried some of them but i am not sure if they are right.
What is the mass of one mole of aluminum?
I don't understand how to do this and
What is the mass of one mole of hydrogen?
1.008 g
2.040g
3.000 g
1008 g
What is the mass of one mole of carbon dioxide, CO2?
3.4007 x 102 g
2.2 x 102 g
4.4009 x 101 g
22.09 x 102 g
What is the mass of one mole of sulfuric acid?
9.8079 x 101 g
98.079 x 103 g
980.79 x 105 g
98079 x 101 g
How many moles in 3.00 g H2SO4?
.059 mol
.390 mol
4.03 mol
.030 mol
How many moles in 12.0 g CH4?
.748 mol
22.5 mol
.495 mol
.952 mol
How many moles in 3.40 x 101g CaO?
.0900 mol
.0456 mol
.945 mol
.606 mol
How many moles in 13.4 g SO2?
.45 mol
.21mol
.97 mol
.25 mol
What is the mass of 0.369 mol N2?
10.337 g
14.986 g
12.031 g
15.0987 g
What is the mass of 10.0 mol Ca(NO3)2?
1596 g
12906g
1641 g
1498 g
What is the mass of 1.94 x 10-3 mol C6H12O6?
.340 g
.456 g
.905 g
22.5 g
What is the mass of 0.0112 KCl ?
5.956 g
How many particles in 25.9 mol Fe ?
1.56 x 1014
How many particles in 0.30 mol NaCl ?
1.8 x 1034
How many moles in 4.7 x 1024 atoms Cu?
7.8
How many moles in 8.30 x 1025 molecules H2O?
156
For the first few questions n=M/m is your equation.
n= # of moles
M= mass in Kg
m= molecular mass (sum of neutrons and protons)
Not to sure about the molecule and particle questions.
I'm pretty sure there is 6.02*10^23 atoms in 1 mole.
This is solved by units where moles=g/g/mole and moles equals atoms/atoms/mole, these two should help solve for exchanges to mass and number of atoms.
thanks:) I will try it and see if it helps you guys:)
1. What are moles and why do they need to be removed?
Moles are small dark spots or growths on the skin caused by clusters of pigment cells. They may need to be removed if they are changing in size, shape, or color, or if they are causing discomfort or irritation.
2. How are moles removed?
Moles can be removed through various methods such as surgical excision, shaving, or laser removal. The method used will depend on the size, location, and type of mole.
3. Is mole removal painful?
The level of pain experienced during mole removal will vary depending on the method used and individual pain tolerance. Local anesthesia is typically used to minimize discomfort during the procedure.
4. Are there any risks associated with mole removal?
As with any medical procedure, there are potential risks associated with mole removal, such as infection, scarring, or changes in skin pigmentation. It is important to discuss these risks with your doctor before proceeding with the removal.
5. Can moles grow back after removal?
In some cases, moles may grow back after removal, especially if they were not completely removed. However, most moles do not grow back after they have been removed using proper techniques.
15K
14K
16K
