Is energy transfer in a chemical reaction always from potential to kinetic?
The discussion centers around the energy transfer mechanisms in chemical reactions, specifically whether energy transfer is always from potential to kinetic energy. Participants explore concepts related to endothermic and exothermic reactions, bond formation and breaking, and the implications of temperature changes during these processes.
  • Some participants express confusion about the relationship between endothermic and exothermic processes and energy transfer, particularly in terms of kinetic and potential energy.
  • It is noted that breaking bonds requires energy, while forming bonds releases energy, though the reasons for this release are questioned.
  • One participant states that in exothermic reactions, the products have stronger bonds than the reactants, implying a stability that results in energy release.
  • Conversely, it is suggested that in endothermic reactions, the reactants have stronger bonds than the products, leading to energy absorption.
  • Questions arise regarding how heat is consumed in reactions and whether stronger bonds correlate with increased or decreased kinetic energy of atoms.
  • A later reply introduces the concept of activation energy and its role in reaction rates, suggesting that heat is added to overcome this energy barrier.
  • Another participant emphasizes the complexity of enthalpy and its distinction from heat and temperature, indicating that enthalpy changes are related to the system's energy state.
Participants do not reach a consensus on the mechanisms of energy transfer in chemical reactions, with multiple competing views and ongoing questions about the implications of bond strength and energy changes.
Some limitations in the discussion include the lack of clarity on how energy transitions between potential and kinetic forms, the dependence on definitions of terms like enthalpy, and unresolved questions regarding the relationship between bond strength and kinetic energy.
Werg22
Endothermic / Exothermic
I have to say that I am a little at loss here. I understand that an endothermic process absorbs more energy than it releases, and that an exothermic process is the opposite. However, I don't understand the implications in terms of kinetic and potential energy. Here is what I have seized so far:
- Breaking bonds requires energy (This is understandable)
- Forming bonds releases energy (Why?)
- In an exothermic reaction, the bonds of the products are stronger than those of the reactants.
- In a endothermic reaction, it is the opposite.
Now how exactly is energy transferred from potential to kinetic? If in a reaction, the temperature rises, is it endothermic or exothermic?
Electrons form the bonds, and if the temperature in a reaction is increasing does that correspond to an increase in heat (release) or a decrease in heat (consumption)?
Ok. But how is heat consumed exactly? When bonds get stronger, kinetic energy is transferred to atoms? I don't really get the logic, since if bonds get stronger, the more restraint atoms and thus would have less kinetic energy...
Sounds like a lot of hand waving unless you have studied the quantum mechanics of the chemical bond (covalent).
Heat is added to a reaction to overcome the activation energy, the lower the activation energy the more rapid the reaction, the higher the activation energy, the more slowly the reaction.
Forming Bonds releases energy because bond formation is a stablizing process. Something is said to be more stable with respect to something else if the former has lower energy than the later. Everything in nature has to tendency to attain stability by lowering its energy this is done simply by releasing energy in some form (Heat or EM waves for instance).
As discussed above the more stronger the bond, lower is its energy. Since energy is released in an exothermic process the energy of the reactants must be greater than the products (This difference is what that is released) or in other words the product is more stable than reactants which in turn means that product must be having stronger bonds than reacants
Just the opposite of my previous answer.. :-)
Atoms in a molecule are in the nuclear force field of other atoms, as such work has to be done by external agent in order to move atoms against the field and work is given to external agent when we move it closer. in this respect all atoms have some amount of energy due to the position it has with respect to other atoms. if we have to change the position some energy change has to occur, this happens in the form of work which in turn changes the state of motion of atoms (or kinetic energy).
Energy can be transferred as heat. The terms 'endothermic' and 'exothermic' pertain to changes in enthalpy, and enthalpy is defined as H=U+PV, where U is the internal energy, P is the pressure, and V is the volume. Heat and temperature and not equivalent to enthalpy. In actuality, the enthalpy concept is a bit complicating, it entails the steps that are required to create the system from a preliminary "standard" state.
48K
90K
