Conservation of momemntum and relative velocities
This discussion centers on a physics problem involving the conservation of momentum and relative velocities. A 39.7 kg girl walks at a speed of 1.58 m/s on a 101 kg plank, which is initially at rest on a frictionless surface. The girl’s velocity relative to the ice surface is calculated to be 5.59 m/s, while the plank moves in the opposite direction at approximately -1.58 m/s. The correct approach involves using conservation of momentum to establish the relationship between the velocities of the girl and the plank.
  • Understanding of conservation of momentum principles
  • Knowledge of relative velocity concepts
  • Basic algebra for solving equations
  • Familiarity with Newton's laws of motion
  • Study the conservation of momentum in closed systems
  • Learn about relative velocity in one-dimensional motion
  • Practice solving problems involving multiple objects in motion
  • Explore the implications of frictionless surfaces in physics problems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of momentum and relative velocity problems.
FaNgS
This is a problem about relative velocities and conservation of momemtum.
Here is how the problem goes:
A 39.7 kg girl is standing on a 101 kg plank. The plank, originally at rest, is free to slide on a frozen lake, which is a flat, frictionless supporting surface. The girl begins to walk along the plank at a constant speed of 1.58 m/s to
the right relative to the plank.
(a)What is her velocity relative to the ice surface?
(b)What is the velocity of the plank relative to the ice surface?
Working:
The way I'm thinking is that since the girl is moving to the right with a speed v=1.58 m/s then the plank moves (after being at rest) with the same speed v=1.58m/s but in the opposite direction (left) so its more like that the speed of the plank is -1.58 m/s.
Considering that, the ice surface is moving to the right with the same but opposite speed v, which is then 1.58 m/s.
Kinda sounds weird to me. I tried using conservation of momemntum also and said that:
(39.7)(1.58) + (101)(0) = 39.7(V) + (101)(-1.58)
then V is about 5.59 m/s
Please advise
As for part B, i haven't been able to figure that one out. I don't know if conservation of momentum should be used or some other method to solve it.
Help is greatly appreciated
Your truly,
Fangs
aww no replies yet
well i found something out but I'm not sure if i understood it correctly from my textbook
the speed of the girl relative to the plank doesn't it mean:
Vg - Vp = 1.58
where Vg is the speed of girl and Vp is the speed of the plank
help is greatly appreciated
Vg - Vp = 1.58
That's correct. Vg and Vp are the speeds of the girl and plank with respect to the ice. Now write the equation for conservation of momentum. You'll have two equations and two unknowns--solve!
