Organic Chemistry Help (Sodium Borohydride Reduction)
The discussion focuses on the mechanism of sodium borohydride (NaBH4) reduction of ketones. It is established that one hydride ion from NaBH4 attacks the ketone, leading to the formation of an alkoxide intermediate. The driving force for the B-H bond cleavage is attributed to the stability of the resulting alkoxide and the solvent environment, typically an alcohol, which facilitates the reaction. The participants concluded that the O-B bond is more stable than the B-H bond, making the latter more reactive in this context.
  • Understanding of sodium borohydride (NaBH4) chemistry
  • Knowledge of ketone structures and reactivity
  • Familiarity with alkoxide formation and protonation mechanisms
  • Basic principles of electronegativity and bond stability
  • Study the mechanism of sodium borohydride reduction in detail
  • Learn about the role of solvent systems in organic reactions
  • Investigate the stability of alkoxides and their reactivity
  • Explore the stoichiometry of borohydride reductions with various carbonyl compounds
Chemistry students, organic chemists, and researchers interested in reduction reactions and mechanistic organic chemistry will benefit from this discussion.
twt
Hi all,
In a sodium borohydride reaction, one of the hydride in BH4- will attack the ketone, and the O- in the ketone will bond with the BH3. This would continue until all the hydride ions are used up.
My question is..what would be the driving force that makes the B - H break and attack the ketone.
Also, after you have one or more ketone bonded with the Boron, can't the O - B bond break and attack the ketone instead of the B - H bond?
My group have no idea for the first question...the most possible answer we came up with is: "it just happen".
The second question...we just take a guess that the O - B is much harder to break compared with B - H, and maybe it has to do with the electronegativity.
Thank you very much.
I will add some more questions later when we finish figuring out the exact mechanism for NaBH4
The solvent system for most borohydride reductions is an alcohol. It must be a solvent that solvates the sodium borohydride. The oxygen from the ketone does not usually bond to the borane but rather the solvent does. The proton from the solvent protonates the alkoxide generated from the ketone to produce an alcohol. That is where the reduction ends for that particular borohydride anion... a new molecule of BH4- is required for each ketone reduced.
chemisttree said:
...That is where the reduction ends for that particular borohydride anion... a new molecule of BH4- is required for each ketone reduced.
Whoops! Wrong again! All 4 hydrogens can reduce the carbonyl and the stoichiometry is 4 carbonyls to 1 borohydride...
:redface:
  • · Replies 28 ·
19K
  • · Replies 20 ·
