Solving Weierstrass M Test Problem with Infinite Series
  • Context: Graduate
  • Thread starter Thread starter robousy
    Test
The discussion revolves around the Weierstrass M test for establishing uniform convergence of a series involving exponential functions. Participants are exploring the application of the M test to a specific series and clarifying the notation and concepts involved.
  • Homework-related
  • Rachel seeks help with a homework problem involving the uniform convergence of the series Sum from n - infinite exp(in^2x) / n! for |z| < r.
  • Cookiemonster questions the notation used in the problem, specifically the expression exp(in^2x / n!).
  • Some participants explain the Weierstrass M test, stating that uniform convergence can be established if the absolute values of the terms are bounded by a convergent series of constants M_n.
  • There is confusion about whether x is a real or complex number, with some suggesting that the problem is easier if x is real.
  • One participant proposes that if x is real, the series converges uniformly on the real line, while expressing doubt about convergence for complex x.
  • Another participant emphasizes the need to find a specific M_n for each term and clarifies that the convergence of M_n is necessary for the application of the M test.
Participants express differing views on the nature of x (real vs. complex) and its implications for the convergence of the series. There is no consensus on the overall conclusion regarding the uniform convergence of the series.
There are unresolved questions about the assumptions regarding the nature of x and the specific application of the M test to the series in question.
robousy
Hi,
I don't really grasp the M test for convergence and I have several Hmwk problems and figured that if someone could explain how to do one of them then I should be able to figure the rest out.
ok - the problem is this:
Use the M test to establish the uniform convergence of:
(Sum from n - infinite) exp(in^2x) / n! for |z| < r where r < infinite.
Any help would be really appreciated
rachel.
I think you need to clear up your notation first.
What is "exp(in^2x / n!"?
cookiemonster
The test states that
[tex]\sum a_n(x)[/tex]
converges absolutely and uniformly on some set of values of X if for all x in X |a_n(x)|<= M_n and
[tex]\sum M_n[/tex]
converges.
So all you need to do is show the n'th term's absolute value satisfies this rule for some constant M_n, and the sum of these constants is convergent.
Hi, the notation exp(in^2x) / n!
means e to the power of i times n squared times x, all dividewd by n factorial where e is the exponential function, i is the aquare root of minus 1, n runs from 0 to infinity.
I still don't understand how to do this problem. :(
Reread the statement of the Weierstrass M test. It takes no understanding to actually use the test:
a_n(x) = exp(ixn^2)/n!
So what can you say about the absolute value of the n'th term in the series? So what is the sum of these values? Hence...?
well - i probably wouldn't have posted a message if I understood the M test now would I?
well - if the nth term is less than infinity, then exp(in^2x) is very big for some huge but not infinite value, and the denominator n! is also very big. Great, I still don't know if it converges or not!
Firstly can you tell me if x is a real number or a complex number? your initial post half indicates complex by saying |z|<r some r, yet you use x inside the sum.
If x is real this question is easy, though it appears from your last post that it might be complex.
Understanding why the M test works and using it are two entirely different things.
Let us assume x is real because I think the question is wrong if we assume x is complex.
the n'th term in the series is
a(n) = exp{ixn^2}/n!|a(n)| = 1/n!, let this be M_n
then sum M_n is convergent so the initial series is unifomrly convergent on the whole of the real line.
I don't think it works for complex x since x = -it, for t some real number requires us to sum:
e^{tn^2}/n!
and that series deoesn't even converge as the ratio of consecutive terms is:
e^{t(n+1)^2 -tn^2}/(n+1) = e^(2tn+t)/(n+1) which tends to infinity as n tends to infinity.
Hi,
Thank-you Matt. I appreciate the time you've spent looking at this.
Yes - it is a complex question but with x real.
So - essentially all you have to do is take the modulus of whatever you are summing over, and then see of the number gets closer to zero as n goes to infinity. Is it is straightforward as that?
Not quite - you must find for each n, a number M_n such that |a_n(x)|< M_n for all x in the domain, where a_n(x) is the n'th term in the series. It will be a different M_n for each n.
Then the sum from 1 to infinity of the M_n must be finite (which is not the same as the M_n tending to 0).Example:
[tex]\sum x^n/n![/tex]
for x in the complex numbers and |x| < 10, say.
a_n(x) = (x^n)/n!
so |a_n(x)| < 10^n/n! := M_n
now sum 1 to infinity of M_n converges hence the function is unifomrly continuous on the disc |x|<10
  • · Replies 24 ·
