How Does Storing Magnets North to South Affect Their Longevity?
Storing magnets with a north-to-south orientation and a 50mm gap can impact their longevity, but the effects depend on several factors. Keeping magnets closer together is preferable, as a slight gap may reduce the preservation of magnetization. The preservation effect is influenced by the distance squared relative to the area of the magnets, indicating that greater distance diminishes the effect. Additionally, the longevity of the magnets is affected by temperature and the specific properties of the magnetic material. Proper storage techniques are essential for maintaining magnet strength over time.
personelsogno
I guess I do have to ask some questions on magnet storage. Especially over long periods of time. Basically, I want to know what the effects are if you store (relatively strong) magnets north to south with a slight gap in between (roughly 50mm between).
N===S N===S N===S
That's pretty much the best crude ascii drawing I can do. Anywho, if there is an effect, what would it be relative to time and to distance apart?
That arrangement would tend to preserve the magnetization.
It would be better if they touched. 5 cm seems like too much.
The preserving effect depends on d^2/A(area). If this is not<<1, the effect would tend to fall off as 1/d^2.
The time dependence depends on temperature and the particular characteristics of the magnetic material.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
