Is This Uncertainty Propagation Correct?
The discussion centers on the correctness of uncertainty propagation in two calculations. The first calculation, involving the sum and product of variables, is confirmed to be accurate. However, the second calculation regarding the uncertainty of a reciprocal is deemed incorrect; the correct approach involves adding the relative uncertainties of the numerator and denominator. The absolute uncertainty should be calculated as the product of the reciprocal and the relative uncertainty of the variable. Overall, the participants clarify the methods for correctly propagating uncertainty in these mathematical expressions.
lapo3399
For the following calculation, would the uncertainty propagate as I have estimated?
\frac{\left(a \pm \Delta a \right) + \left(b \pm \Delta b \right)}{\left(c \pm \Delta c \right) \cdot \left(d \pm \Delta d \right)} = \frac{a+b}{cd} \pm \frac{a+b}{cd} \left( \frac{\Delta a + \Delta b}{a + b} + \frac{\Delta c}{c} + \frac{\Delta d}{d} \right)
Thanks.
Yes, looks good to me.
Thanks!
One more quick question - is the following uncertainty propagation correct also?
\frac{1}{ \left( r \pm \Delta r \right)} = \frac{1}{r} \pm \frac{1}{ \Delta r}
Thanks again.
lapo3399 said:
Thanks!
Thanks again.
That doesn't look right to me. To get the relative uncertainty of the fraction... add the relative uncertainty of the top (0)... to the relative uncertainty of the bottom...
So the relative uncertainty of the fraction seems to be \frac{\Delta r}{r} so the absolute uncertainty would be \frac{1}{r}\times \frac{\Delta r}{r}
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
