Stokes Theorem Problem: Evaluating Line Integral with Vector Field
Simfish
Let C be the closed curve that goes along straight lines from (0,0,0) to (1,0,1) to (1,1,1) to (0,1,0) and back to (0,0,0). Let F be the vector field F = (x^2 + y^2 + z^2) i + (xy + xz + yz) j + (x + y + z)k. Find \int F \cdot dr
By Stokes Theorem, I know that I can transform this into a curl (instructions say don't evaluate the line integral directly).
So I know I get a form of square that goes CCW. Projected on the xz-plane, it is simply a square (but the y-coordinate of the right end is 1).
I think the plane is described by x = z, since there is no dependence on y. So x-z = 0
Anyways, I take the curl of F to get
F \cdot dr = (1-x-y) i + (1-2z) j + (y+z-2y) k.
I take the dot product of this with the plane z - x = 0 to get
\nabla f = -i + k
and dot that with F to get
F \cdot \nabla f = x + y -1 + y + z - 2y = x + z -1
so then
\int_0^1 \int_0^1 (x + z -1) dx dy. Since x = z...
\int_0^1 \int_0^1 dx dy = \int_0^1 x^2 - x dy = \frac{1}{3} - \frac{1}{2} = - \frac{1}{6}
am I doing this correctly?
Part of your LaTex didn't come through. How do you take the dot product of a vector with a plane?
And what do you mean by "dot that with F"?
You have F \cdot \nabla f
That confuses me greatly. You have a function "F" but say nothing about "f". If you meant F \cdot \nabla F, that is not at all what you want.
Stokes theorem has
\int\int \nabla \times \vec{F}\cdot \vec{n}dA
Okay, here you have the dot product of a vector with the gradient of the plane:
http://tutorial.math.lamar.edu/classes/calcIII/stokestheorem.aspx
(example 2). But this could be confusing, and there is an alternative way to express Stokes Theorem after the dot product has been taking.
This is Stokes Theorem as a surface integral. (the gradient approach to the surface integral is at http://tutorial.math.lamar.edu/Classes/CalcIII/SurfIntVectorField.aspx )
As we know,
\int\int \nabla \times \vec{F}\cdot \vec{n}dA = \int\int F \cdot dS = \int\int -P \frac{\partial g}{\partial x} - Q \frac{\partial g}{\partial y} + R
where
\nabla \times F(x,y,z) = P i + Q j + R k and g = f(x,y) = z
The equation of my plane should be z = f(x,y) = x, right? (the plane is f, and determined by "Let C be the closed curve that goes along straight lines from (0,0,0) to (1,0,1) to (1,1,1) to (0,1,0) and back to (0,0,0).")
in that case, \frac{\partial g}{\partial x} = 1, \frac{\partial g}{\partial y} = 0
So correcting my arithmetic..
F \cdot \nabla f = -(1 - x - y) + y + z - 2y dA
= \int_0^1 \int_0^1 -1 + x + z
We take z = x. Is this an appropriate choice? If so
\int_0^1 \int_0^1 2x - 1 dx dy = \int_0^1 x^2 - x (1,0) = \int_0^1 0 ...
what am I doing wrong here?
You set g = f(x,y) = z, so your D will be the projection of graph g at x-y plane.
You can substitute z=x at there. I got zero as well for this question.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
