How Do I Solve This Projectile Motion Problem?
  • Thread starter Thread starter DanielP
    Projectile
DanielP
Hello fellow forum trolls,
I am currently pondering about this physics problem that was assigned to me on a day I was not in school and I have some confusion on the process in which to solve it.
Essentially we have to cannon out a metal ball through a hoop a certain distance away.
We know the initial velocity of the ball, The DeltaY of the hoop, and we have control over the DeltaX. To pass the project we must determine where to set the Hoop in respect to the launcher to get the ball through.
so far my data goes as follows
The launcher is at 30 degrees launching out at a velocity of 5.85
....X....Y
Vi...5.073 m/s...2.92 m/s
Vf...5.073 m/s
D......| .265m
a...0...-9.8 m/s^2
t
So my questions are,
For my final velocity of Y i got 3.711 but I feel that it doesn't seem write. I used the formula Vf^2=Vi^2+2a(DeltaY)
other formulas to use
Vf=Vi+at
Delta=Vi*t+1/2at^2
Delta=((Vi+Vf)/2)*t
After that I cannot figure out how to find DeltaX
If you could point me in the write direction or help check my work that would be amazing.
Thanks for your help
....X....Y
Vf...5.073 m/s
D......| .265m
a...0...-9.8 m/s^2
t
You must use a_y = -9.80 m/s^2. Looks lik eyou used a positive acceleration.
Vf=Vi+at
Delta=Vi*t+1/2at^2
Delta=((Vi+Vf)/2)*t
use the equations along y find the time it takes to reach the hoop. Then go along x (where a_x=0) to find the delta x.
Thanks for the help,New Vfy is -2.274
Time i got .53 s
and for DeltaX I found 2.688 m
thanks for the help
New Vfy is -2.274
Time i got .53 s
thanks for the help
mmmm...
I get -1.83 m/s for v_{fy}
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
