Understanding Compactness in the Graph of a Continuous Function
  • Context: Graduate
  • Thread starter Thread starter SiddharthM
    Function Graph
The discussion revolves around the concept of compactness in the graph of a continuous function between metric spaces. Participants explore the implications of compactness, continuity, and the properties of graphs in the context of metric spaces, with references to specific theorems and proofs.
  • One participant questions how to interpret open sets in the product space of the graph of a continuous function, referencing Rudin's text and the compactness of finite Cartesian products.
  • Another suggests that Tychonoff's theorem might be applicable, while also considering the possibility of a proof based on convergent subsequences.
  • A participant expresses uncertainty about the generality of the compactness result, noting that while one direction holds, the reverse may not be true in all cases.
  • One participant claims to have proven the compactness of the graph under the assumption that the domain is compact, providing a detailed proof involving limit points and sequences.
  • Another participant acknowledges the proof but emphasizes the importance of the compactness assumption in the context of metric spaces.
  • A later post seeks clarification on whether the established proof also applies to a specific definition of compactness related to functions between metric spaces.
  • One participant expresses confusion regarding the formatting of a question posed by another, indicating a communication barrier in the discussion.
Participants express differing views on the generality of the compactness result, with some asserting it holds in general metric spaces while others question this assertion. The discussion remains unresolved regarding the applicability of the proof to the broader definition of compactness in functions between metric spaces.
Participants reference specific theorems and properties, such as Tychonoff's theorem and the Extreme Value Theorem, but the discussion does not resolve the dependencies on definitions or the scope of the results discussed.
SiddharthM
Consider two metric spaces, X and Y with X being compact. Let f:X --> Y and define graph(f)=set of all points (x, f(x)) with x inside X. Then f is continuous iff it's graph is compact.
Well my main question is how do we make sense of open sets in the space in which the graph is contained? I'm aware that since because this is a finite product the product topology is equivalent to the inherited topology on the product (that is defining an open set to be the product of open sets in each X and Y) - that being said my book (Rudin) doesn't go that far in fact he doesn't MENTION metric spaces that are products of other metric spaces (except for n-space of course) Can I just assume a finite Cartesian product of compact sets is compact? Or does Rudin want me to solve it for euclidean spaces only?!
Seemingly you could use Tychonoff's theorem, but perhaps Rudin is looking for a convergent subsequence proof? (Only guessing.)
I will post a proof here later. We will see how much generality I get out of it.
I tracked this down in my copy of Rudin. Judging by the way he has it phrased, I think he wants you to prove it when X is a compact subset of R (under the usual topology).
Actually, I don't think this is even true for general metric spaces. One direction definitely is -- namely that if graph(f) is compact then f is continuous -- but if f is continuous, then graph(f) need not be compact. For example, if we take R with the discrete metric, and let f:R->R be the identity function, then f is continuous, but its graph is not compact: {{y}x{(y-1, y+1)} : y in R} is an open cover of it that has no finite subcover. Hell, even if we give R its usual metric the graph of f still won't be compact (Heine-Borel); in fact, this is where the compactness hypothesis of the problem kicks in: the real-valued, continuous image of a compact space is bounded (Extreme Value Theorem).
Edit:
Also, I thought I might add that the full strength of Tychonov isn't really required for finite products.
So - it IS true for general metric spaces! I have proven it.
Morphism - Note that the domain of definition of f is COMPACT by hypothesis which R itself isn't!
Definition: For a sequence in a Cartesian product to converge, it's individual components must converge to the appropriate value.
Proof: (Forward direction) Arguing contrapositively assume graph(f) is not compact. Since limit-point compactness is equivalent to compactness in metric spaces there exists an infinite set,F, in the graph(f) that has no limit point. This infinite subset of the graph corresponds to an infinite subset,E, of the domain of f. Because the domain of f is compact E has a limit point. Call it x, then there is a sequence x_n in E that goes to x. Since (x,f(x)) is not a limit point of F the sequence (x_n,f(x_n)) doesn't tend to (x,f(x)). And by our above definition and the fact that x_n goes to x, this is because f(x_n) doesn't converge to f(x).
Now suppose graph(f) is compact. Take a sequence in the domain of f that converges to x, call it x_n. If x_n had finitely many values then it is clear that limf(x_n)=f(x), so assume it has an infinite set of values. Then this sequence corresponds to a sequence with infinite values in graph(f), since graph(f) is compact this sequence has a limit point in graph f, call it (y, f(y)). So there must be a subsequence of (x_n,f(x_n)) converging to (y, f(y)), since x_n converges to x, y must be equal to x. Clearly no other point in graph(f) can be a limit point of (x_n, f(x_n)). Let V be a neighborhood of (x, f(x)), there cannot be infinitely many (x_n,f(x_n)) in the compliment of V b/c the compliment of V is a closed subset of a compact set and is therefore compact. So an infinite number of (x_n,f(x_n)) implies the sequence has another limit point, which is impossible. So (x_n, f(x_n)) converges to (x, f(x)) and f(x_n) converges to f(x).
QED.
I seem to have missed that you stated X was compact. Yes it is true in this case.
Please help
I just want to ask that what you have shown is it also a proof of the following or not?
If not can you help me with this please.
We define:
a function $f:M\to N$ between two metric spaces specifies
compactness if it has the property
$K\subset M $ is compact $\Leftrightarrow \left\{(k,f(k))|k\in K
\right\}\subset M\times N$ is compact.
Then $f$ specifies compactness $\Leftrightarrow$ $f$ is continuous.
I have to say I don't udnerstand your question because the latex isn't coming out!
