A woman pulls a suitcasewhat is the angle with the horizontal?
In summary: This means that the normal force is equal to the weight of the suitcase plus the vertical component of the tension. This is what your teacher was trying to show.Now that we have that out of the way, let's enter in the numbers.-Sin\theta + N = 0N = sin\thetaN = (20kg)(9.8m/s^{2})sin(55.15^{o})N = 159.8NThis is still a bit confusing to me, but I'm sure you'll get it.
~christina~
[SOLVED] A woman pulls a suitcase..what is the angle with the horizontal?
A woman at the airport tows her 20.0kg suitcase at constant speed by pulling on strap angle theta above the horizontal. She pulls on the strap with 35.0N force. The frictional force on suitcase is 20.0N
a) what angle does the strap make with the horizontal?
b) What normal force does the ground exert on the suitcase?
[tex]\sum Fx= max= Fcos-f = 0[/tex]
[tex]\sum Fy= may= N + Fsin theta - mg = 0[/tex]
F= ma
a.)
I know that the equations are these to get the solution of the angle however I don't know why the Fy is what the equation states it is. (the equation was given by my teacher and I didn't understand why he gave this equation since it wasn't explained)
The thing is..focusing on [tex]\sum Fy= may= N + Fsin theta - mg = 0[/tex]
I do know why it's = to N-mg but why is it adding Fsin theta?
b.) For this part I'm kind of confused as to the way they state the question.
"what normal force does the ground exert on the suitcase?"
normal force is usually what the suitcase exerts on the ground which is :F= mg
but wouldn't the normal force the ground exert on the suitcase be equal but opposite in direction?
thus..
N suitcase= -N ground
m(-g)= m(g)
Is this fine?
Thanks a lot :smile:
F= ma
a.)
thus..
m(-g)= m(g)
Is this fine?
No. for part a, you need only look in the x direction and solve for theta from that equation. For part b, the normal force in the y direction would be equal to the weight only if there was no other force acting in the y direction. In your case, the vertical component of the pulling force of 35N is pulling up on th suitcase, such that the normal force is less than the weight. That is where the equation in the y direction comes from...it is still in equilibrium in the y direction, with the 3 forces (weight, normal force, and y component of pulling force) acting together in the y direction to yield a net force in the y direcion of 0.
a.)
you add it because that is the component of the woman's pulling force in the y-direction. It acts in the same direction as the normal force.
For part b.) so...is it the normal force that the ground is exerting on the suitcase = to
N= mg- F sin theta ?
I assume it would be but would the normal force be equal magnitude just oposite direction thus -N?
Thanks :smile:
To start with, this is very similar to a problem I had in my college physics course not too long ago. This time the given information was different so it took some tweaking to get the answers and I kept getting confused. However, when I reread the problem carefully, it made a whole world of difference. I'll go ahead and explain below.
a)[tex]\Sigma F_{x} = F - f = ma_{x}[/tex]
Once you understand the steps, you'll probably kick yourself for not seeing it. It just takes some algebra to get there.
Given:
[m]ass = 20kg
[T]ension = 35N
[f]riction force = 20N
[a]cceleration (on the x-axis) = 0 [tex]m/s^{2}[/tex]
The letter in the boxes are what I will be using to denote each quantity in the equations.
Now, force F is actually the cosine of the tension on the rope, and this will be detonated as:
[tex]F = Tcos\theta[/tex]
We also now that the suitcase is moving at a constant speed, which means that it's acceleration is zero.
Now, we can enter in the equation.
[tex]Tcos\theta - f = ma_{x}[/tex]
From here, we want to move f to the right to help isolate theta.
[tex]Tcos\theta = ma_{x} + f[/tex]
Now, we can also pull T off by divided both sides by T
[tex]cos\theta = \frac{ma_{x} + f}{T}[/tex]
That only leaves us with cosine theta on the left. To completely isolate theta, we have to use the inverse of cosine on the right.
[tex]\theta = cos^{-1}(\frac{ma_{x} + f}{T})[/tex]
From here, we can enter in all of the known data we have and find theta.
[tex]\theta = cos^{-1}(\frac{(20kg)(0m/s^{2}) + (20N)}{35N})[/tex]
[tex]\theta = 55.15^{o}[/tex]
Now we can go onto part B
b) Since we now have the angle theta, B becomes REALLY easy.
Using your equation that your teacher gave you (which I will also explain why it is zero), you can enter in the known values to find the answer.
[tex]\Sigma F_{y} = -W + N + Tsin\theta = 0[/tex]
This is essentially your same equation, just I have have weight represented as 'W' instead of 'mg'. Now, the reason for the equation being equal to zero is this: When you consider that the force the suitcase exerts on the ground is equal to its weight times the force of gravity, the ground must exert an equal and opposite force according to Newton's Third Law. That is where the normal force comes in or force N.
In this problem, the two forces are equal, however, you must also consider that the woman is pulling the suitcase up slightly, effectively reducing the force that the suitcase is exerting on the ground and in turn, reduces the normal force.
Now, I've represented this in the equation above. The weight is negative because it is pushing down while the normal force and the force of the vertical tension are both pushing up.
To find the normal force, we must essentially do the same thing we did to isolate theta in part A. To do this, simply move everything over to the right side, leaving N all by its lonesome.
[tex]N = W - Tsin\theta[/tex]
Because both quantities moves across they change their signs, so W becomes positive and TsinTheta becomes negative. From here, we can enter in our known quantities and find N. Also remember that W = mg
[tex]N = mg - Tsin\theta[/tex]
[tex]N = (20kg)(9.8m/s^{2}) - (35N)sin(55.15^{o})[/tex]
[tex]N = 167.28N[/tex]
And that wraps it up, if you have any more questions, feel free to message me.
P.S. Sorry for the essay-like response
Wow..um that makes everything clearer..now if only my teacher explained it all like that..
thanks very much firefly 1 :smile:
No problem. Glad it makes sense to you now. If you have any more questions on further assignments, feel free to ask me.
Sure will..You make things much clearer :smile:
FAQ: A woman pulls a suitcasewhat is the angle with the horizontal?
1. What is the relationship between the woman's pulling force and the angle of the suitcase with the horizontal?
The pulling force and the angle of the suitcase with the horizontal are directly related. The greater the angle, the more force the woman will need to exert to pull the suitcase.
2. How can the angle of the suitcase affect the woman's ability to pull it?
The angle of the suitcase can greatly affect the woman's ability to pull it. If the suitcase is at a steep angle, it will require more force to overcome the weight of the suitcase and move it. A shallower angle will require less force.
3. What is the best angle for the woman to pull the suitcase?
The best angle for the woman to pull the suitcase is at a shallow angle, close to the horizontal. This will require the least amount of force and make it easier for the woman to move the suitcase.
4. How can the weight of the suitcase affect the angle with the horizontal?
The weight of the suitcase can directly affect the angle with the horizontal. The heavier the suitcase, the steeper the angle will be when the woman pulls it. This is due to the increased force needed to overcome the weight of the suitcase.
5. Can the angle of the suitcase change while the woman is pulling it?
Yes, the angle of the suitcase can change while the woman is pulling it. This can happen if the woman changes her pulling force or if the terrain changes, causing the suitcase to shift. It is important for the woman to adjust her pulling force to maintain the best angle for pulling the suitcase.
9K
