What is the Potential Energy and Work Done by a Conservative Force?
The discussion revolves around a problem involving a conservative force acting on a mass moving at constant velocity, with specific focus on potential energy, work done by conservative and friction forces, and the implications of constant velocity on net work and energy changes.
  • Mixed
  • Participants explore the calculation of potential energy and work done by both the conservative force and friction. There is confusion regarding the implications of constant velocity on net work and potential energy changes.
Participants are actively questioning the assumptions in the problem, particularly regarding the presence of additional forces and their impact on the calculations. Various interpretations of the relationship between work done, potential energy, and net work are being explored.
There is uncertainty about the wording of the problem and the implications of constant velocity, leading to differing interpretations of the calculations for potential energy and work done. Participants note the lack of clarity regarding whether other forces are acting on the mass.
clipperdude21
1. A conservative force F is directed along the horizontal x direction with F(x) = (2.0x
+4.0)N (where x is expressed in meters). It acts on a 5 kg mass that moves at constant
velocity from x=1.0 m to x=5.0 m. The coefficient of kinetic friction of the mass with the
surface is 0.1.
a) Find the potential energy for the force.
b) Calculate the work done by the conservative force and by the friction force.
c) Calculate the change in potential energy.
2. (a)-dU(r)/dr = F(r) (b) W=Fr (c) W= delta U
3. (a) U(x)=-(x^2 +4x+C) where C is a constant is what I got after taking the integral of F(x)
(b) I graphed the force versus the distance and took the area under the graph from x=1 to x=5. This gave me 40J for the work done by the conservative force. This is where i was confused. Wouldnt the Work done by friction have to be -40J since the object is in constant velocity. However, how would you calculate that? Wfriction=(-static coeff)(mg)(r)=(0.1)(5 x 9.8)(4m)= about -20J is the way I initially thought of doing it but this leads to net work being done which isn't true for constant velocity problems right?
(c)The change in potential energy should be 0 J because the object is in constant velocity and the net work done on the object is 0J. Or is the change in potential energy 40 J since if you plug in U(1)- U(5) into the equation found in (a) you get 40 J
Thanks in Advance!
I think the question is trying to "trick" you with the constant velocity part... the question doesn't explicitly state that there are no other forces acting on the object...
a) looks good. b) is just -20J I believe... just like you did (force of friction)*4m
however c) I think is just -40J... using your potential energy formula... can you explain your reasoning for saying 0?
oh okay so wait the object isn't in constant velocity?
(b) so if the W friction is -20 J, the work of the force can still be 40J? so the works don't have to be equal?
(c) my reasoning for saying it was 0 was that i thought that net Work= change in potential energy. I thought that if the object was in constant velocity which means 0 net work and consequently the change in potential energy 0 J
No it is in constant velocity... What I meant was there are additional forces that are not explicitly mentioned that are keeping the object at constant velocity.
If they were the only forces, then they'd have to add to zero... but I think there's supposed to be other forces...
I just presumed that by potential energy they were referring to the potential energy due to that one force... the problem is we don't know if the other forces involved are conservative or non-conservative... only conservative forces have potential energies...
There's 2 ways to look at it...
Net work done by all forces = change in kinetic energy
net work done = 0.
But
net work done by non-conservative forces = change in kinetic energy + change in potential energy (for all the conservative forces involved).
it could be that friction is the only non-conservative force... and everything else is conservative... in which case we can plug into this second equation:
-20 = 0 + change in potential energy
giving change in potential energy = -20J
we could assume those other forces are non-conservative... which would mean that there's another non-conservative force doing -20J of work...
-20 + (-20) = 0 + change in potential energy.
change in potential energy = -40J (here the only potential energy is due to the one given force).
Maybe we're supposed to presume that anything other than friction is conservative... I'm not sure.
ok that makes sense... this is a very poorly worded question since its not very clear. Thanks a lot for your help!
i was looking at (c) again and couldn't be just plug in 5 and 1 into the function U(x) calculatd in (a). I did U(5)- U(1) and got -40J... How do we know that the Change in potential energy isn't +40J. Shouldnt it be positive since the work of the force is positive?
no prob. yeah I agree with you. At first glance it seems to me like part c) is just asking for the change in energy using the formula you got in part a)...
One more quick question. When we take delta U, does that mean U (initial) - U (final) so would it be U(1) - U(5) and be +40J? for is it U (final) - U (initial) where U(5)- U(1)= -40J
delta U is -40J. It is just final potential energy - initial potential energy.
delta U = U (final) - U(initial) = U(5) - U(1) = -40J.
However the work done by the conservative force involved is -delta U = -(-40J) = 40J
okay i get it now... thanks! i think i was just confused for a little bit since the work of gravity is -Mg(H2-H1) its equal to Wgrav= U(H1)-U(H2). But this is because gravity points downward, opposite a raise in height.
  • · Replies 22 ·
