Work and displacement physics problem
The discussion revolves around calculating the work done by Susan on her dog while pulling it with a force represented by F = (2.2 N)i + (1.1 N)j. To determine the work, the dot product of the force and the dog's displacement must be used. If the dog remains stationary, the net work done is zero; however, if the dog moves, the work is calculated by multiplying the force component in the direction of displacement by the distance. The participants emphasize the importance of understanding vector displacement in relation to the force applied. Ultimately, the correct approach involves using the dot product to find the work done based on the given displacements.
grouchy
To keep her dog from running away while she talks to a friend. Susan pulls gently on the dog's leash with a constant force given by F = (2.2 N)i + (1.1 N)j . How much work does she do on the dog if its displacement is
a) d = (.25 m ) i
b) d = (.25 m ) j
c) d = (-.50 m)i + (-.25 m ) j
My main problem is whether or not I need to combine the force or simply W = Fd. Thx for any help
Well, if we assume that she exerts a force such that the dog remains stationary, the net work done is zero.
however, if the force she exerts brings the dog to her, the we must mutiply the force exerted in this direction with the magnitude of the displacement of the dog from her.
In your above question, you should find the magnitude of the force she can exert and then multiply it by the distance the dog is from her.
I guess the d values in the question say the dog does not remain stationary.
Hi grouchy,
The problem implies that the dog underwent vector displacement d while the given force F was acting on it. Then work done is simply the dot product or the scalar product of F and d. I presume you know how to find that.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
