Can an object travelling really fast catch friction?
  • Thread starter Thread starter Saruwatari
    Friction
An object traveling at high speeds can indeed catch fire due to friction, particularly if it reaches a velocity that generates enough heat to exceed the ignition point of its material. For a soccer ball, the critical speed would depend on its construction material, such as leather, and the temperature at which it ignites. Airplanes experience significant heating at around Mach 2 (1400 mph), suggesting that a soccer ball would need to reach a similarly high speed to catch fire. However, the discussion clarifies that tracer rounds ignite not from friction but from their chemical composition, indicating that not all fast-moving objects catch fire in the same way. Understanding the specific conditions and materials involved is crucial in determining the speed required for ignition.
Saruwatari
let's say i kicked a soccer really strong(and let's say i have insanely super human strength) , is it possible for the soccer ball to catch fire , and if it is at what speed?
Let me answer you with two questions:
(1) How hard could you kick a soccer ball without bursting it?
(2) What material is a soccer ball made of and what happens to that material as it warms?
Airplanes have to be traveling about mach 2 (1400 mph) before they start to worry about airframe heating.
If you get the soccer ball moving fast enough, it will most certainly burst into flames.
Roll down the window on the shuttle and hold your soccer ball out in the wind during reentry, and your soccerball will quickly look like a very large, neglected marshmallow in a campfire.
You don't have to be going that fast though, the temperature at which the soccerball bursts into flame is simply the ignition point of whatever it is made of. Leather?
http://www.tcforensic.com.au/docs/article10.html#2.1.1" (lower than I thought!)
Now all you need so is get someone to calculate the velocity that would create that temp on an object that size and shape.
just think of a tracer round
which is a actual example of something flying so fast it catches fire
What? :eek: They're made with magnesium or phosphorus! They're not burning due to friction!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
