Potential From an Electric Field
To calculate the potential difference between two points in a uniform electric field, the formula used is V = -∫E * dl. In this case, with an electric field of 8 kN/C in the x direction, the potential difference from the origin to 4 m is determined solely by the field and not the point charge. The result of the calculation yields a potential difference of -32 kV, indicating the work done against the field. The presence of the point charge affects the force experienced but does not alter the potential difference calculation. Understanding this distinction is crucial for solving related problems involving point charges in electric fields.
snoweangel27
I have been trying to calculate the potential difference between to points. In doing so, I have tried taking \int -E * dl, in which I end up with -E*4, but that does not include the point charge, and I'm just not sure what I need to do to Calculate the potential with the addition of the point charge.
Question
A uniform electric field of 8 kN/C is in the x direction. A positive point charge Q = 3 micro Coloumbs is released from rest at the origin.
--What is the potential difference V(4 m) - V(0)?
You're doing OK. The potential difference only depends on the field, not on the charge you are putting in the field. (I suspect there will be addition questions for this problem where you will need to use the charge.)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
