Solving Significant Figures Problems - Area of a Parking Lot
  • Thread starter Thread starter chocolatelover
    Significant figures
To find the area of a parking lot measuring 115 ft by 200 ft in square meters, the conversion from feet to meters is crucial. The correct conversion factor is 1 m = 3.281 ft, leading to dimensions of approximately 35.1 m and 61.0 m, not 70.0 m as initially calculated. The area is then calculated as A = (35.1 m)(61.0 m), resulting in approximately 2142.1 m², or 2.14 x 10³ m² in scientific notation. Attention to significant figures and round-off errors is essential for accurate results.
chocolatelover
Hi everyone,
Can someone please help me with this problem?
The problem says:
A parking lot is 115 ft by 200 ft. Find the area in m2
My attempt:
1m=3.281 ft
So (115 ft)(1m/3.281ft)=35.1m
(200ft)(1m/3.281ft)=70.0m
A=(35.1m)(70.0m)
A=2457m2=2.46X10^3m^2
Thank you very much
200/3.281 = 61.0, not 70.
Also watch out for round-off errors.
Thank you very much
Does 2.14 X 10^3 m^2 look right?
Yup:
http://www.google.com/search?q=(115+feet+*+200+feet)+in+meters^2
Thank you very much
Regards
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
