How can poles and zeros help in filter design and control systems?
  • Thread starter Thread starter edmondng
    Poles
Poles and zeros are crucial in filter design and control systems, as they determine system stability and response characteristics. Poles must be in the left half of the complex plane to ensure stability, as right half-plane poles lead to increasing amplitudes and instability. Each reactive component, such as capacitors and inductors, contributes a pole or zero to the transfer function, allowing for direct design of filters based on desired specifications. Stability and system behavior can be analyzed through the transfer function, which provides all necessary information about poles and zeros. Practical implementations often require additional components like op-amps to prevent loading effects between stages.
edmondng
Hi,
I'm trying to gain a better understanding on poles and zeros. Seems everywhere i read it says the poles and zeros can tell you the system response, characteristic and you can do lots with it from filter design to controls. Its a broad area but was hoping someone can provide further information to enhance my understanding like.
Some questions:-
-Why do you always want the poles to be on the left hand side of the complex plane? Do you always want poles to be on the left hand side of the plane?
-How can you design filters from the poles/zeros. Is there a direct relationship between resistors/caps/inductors to poles zeros? Let's say i have an equation for my transfer function , can you pick values for the resistors/inductors/caps to make the n-order filter?
-How do you tell the stability/poles zeros of a control system? I don't see how you can come up with an equation to look at the poles/zeros of a system.
-The closer to a pole means higher gain/amplitude while closer to a zero means lower gain/amplitude.
-A reactive component like caps/inductors produces 1 pole. So if you want a 5 pole system you can get away with 'T' like figure (combine with inductor/resistor) with 2 extra caps on each side of the 'T', for a total of 5 caps. But how do you find the values based on your desired cutoff frequency?
Thanks
Poles in the right half plane correspond to growing amplitudes; for example, a sine wave that keeps getting louder and louder without bound. That's unstable. Poles in the left half plane correspond to exponentially decreasing amplitudes.
Essentially, every reactive element (capacitor or inductor) adds a pole or zero to the transfer function, depending upon how you wire it up. You can indeed go directly from a transfer function to an implementation with discrete RC or RL networks. Normally, you need op-amps or other circuitry to keep one stage from loading the others.
If you have a transfer function, you have everything you can possibly know about your system. You can easily find the frequencies for which the response is zero -- these are the zeroes, of course. Same for the poles.
Essentially, yes.
Again, in practice you would generally isolate each stage from the others with an op-amp or buffer of some kind. Look at the Sallen-Key active filter configuration; it is popular in industry.
- Warren
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
