How Does Temperature Affect Ethanol Vapor Pressure and Mass?
The discussion focuses on calculating the vapor pressure of ethanol at different temperatures using the Clausius-Clapeyron equation. Participants suggest using the ideal gas law to determine the mass of ethanol in vapor form and emphasize that the total amount of ethanol remains constant in the sealed container. For the question about whether all ethanol will vaporize when warmed, it is noted that calculations are necessary to determine if the vapor can reach the required pressure. The conversation also highlights the importance of consistent units in calculations. Overall, the thread provides guidance on solving the problems related to ethanol's vapor pressure and mass at varying temperatures.
fk378
A 4.7-L sealed bottle containing 0.33 g of liquid ethanol, C2H6O, is placed in a refrigerator and reaches equilibrium with its vapor at -11 degrees C.
a) What is the mass of ethanol present in the vapor?
b) When the container is removed and warmed to room temperature, 20 degrees C, will all the ethanol vaporize?
c) How much liquid ethanol would be present at 0 degrees C?
The vapor pressure of ethanol is 10 torr at -2.3 degrees C and 40 torr at 19 degrees C.
My attempt:
a) I have no idea how to approach this.
b) No, because there will be condensation occurring at the same rate as vaporization, once it reaches equilibrium again. (?)
c) I think I need to use PV=nRT for this... but I don't know how to relate the 2 different temperatures I'm getting (0 C and 19 C)
Any suggestions would be appreciated, thank you!
A sketch of the solution.
To attack all three problems here, you need to calculate the vapour
pressure of ethanol as a function of the absolute temperature T.
Use the Clausius Clapyron equation for this:
log p = A/T +B,
where p is the vapour pressure, T the absolute temperature and A and B are
constant. You can easily get A and B from the given vapour pressures at
T=270.85 K and T=292.15 K, which will enable you to calculate the vapour pressure
at 262.15 K, 273.15 K and 293.15 K, or indeed any other temperature.
To find the mass of ethanol in the vapour phase, use the ideal gas
equation to get the number of moles, n:
n = pV/(RT), since V is given and p is the vapour pressure.
From n and the molecular weight of ethanol (C2H5OH), you can calculate the
mass of ethanol in the vapour. Since the vessel is sealed, the amount of
ethanol in the liquid and vapour phases together remains constant.
The answers to (a) and (c) should be easy. The answer to (b) is a bit
trickier because it could be that there is not enough ethanol to produce
the required partial pressure in the vapour. In this case, all of the
liquid will evaporate and your answer to (b) is incorrect.
You will have to do the calculation to see what comes out.
I assume you can take it from here, being careful to choose a consistent
set of units.
pkleinod gave a excellent answer
there is another form of the Clausius Clapeyron equation
Ln(P1/P2)=ΔHVap/(1/T2-1/T1)
which might be easier for your specific question as you can plug in all the variables and not have to solve for C
the R value is a constant, 8.31457 J/K
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
