| Thread Closed |
unit vectors |
Share Thread | Thread Tools |
| Feb12-08, 09:20 PM | #1 |
unit vectors
Vector A=3i-1j and B=-i-4j Find vector A-B and|vector A-B| 2. Relevant equations 3. The attempt at a solution Vector A-B=4i-3j Is the |vector A-B|the magnitude or just the absolute value of the answer? Thank you very much |
| Feb12-08, 09:25 PM | #2 |
|A| is the magnitude of a vector A. To avoid confusion, one can use ||A|| to denote magnitude.
| Feb12-08, 09:27 PM | #3 |
Thank you very much
Is the other part correct? The magnitude is the same thing as the angle of the vector, right? Is there a formula for calculating the magnitude? Thank you |
| Feb12-08, 09:51 PM | #4 |
unit vectors
The magnitude of a vector whose components are <a1, a2> (2 dimensional vector) is:
[tex] \sqrt{a_1^2 + a_2^2}[/tex] Please do not confuse magnitude and direction. Although they are both characteristics of a vector, they are different things. Recheck A-B, the j component has its sign messed up. |
| Feb12-08, 10:00 PM | #5 |
Thank you very much
4i+5j does that look correct? |
| Feb12-08, 10:07 PM | #6 |
Recheck.
Let A = <a1, a2> and B = <b1, b2> A-B = <a1-b1, a2-b2> |
| Feb12-08, 10:11 PM | #7 |
If vector A=3i-1j
and B=-1i-4j in order to find A-B, don't you just do 3i--1i=4i and -1i--4j=3j Wouldn't it be 4i+3j? and is the magnitude of A-B 6.40? Thank you |
| Feb12-08, 10:15 PM | #8 |
Yup
4i+3j is correct. You made the mistake of writing 4i-3j in your initial post.
| Feb12-08, 10:17 PM | #9 |
Thank you very much
Regards |
| Feb12-08, 10:17 PM | #10 |
But your magnitude doesnt look too good. Recheck that.
| Feb12-08, 10:24 PM | #11 |
Thank you
| Thread Closed |
| Thread Tools | |
Similar Threads for: unit vectors
| Expressing cartesian unit vectors in terms of spherical unit vectors | General Math | 9 | ||
| unit vectors | Introductory Physics Homework | 6 | ||
| orthogonal unit vectors also unit vectors? | Calculus & Beyond Homework | 5 | ||
| Need help in Unit Vectors | Engineering, Comp Sci, & Technology Homework | 1 | ||
| gradients and unit vectors | Precalculus Mathematics Homework | 2 | ||
