Monopole Moment of a sphere of charge
lampshade
I'm really bad at these type of problems. I'm supposed to find the monopole moment of this continuous charge distribution. its charge is
\sigma = const*cos(\theta)
p = \int r'\rho(r')d\tau
which then since we are doing a surface charge should be
p = \int r' \sigma da
Well, I want to do the double integral of something to find the charge distribution so I can find the monopole moment. I'm thinking something like
p = \int_{0}^{2 \pi}\int_{0}^{2 \pi} r' * c \cdot cos(\theta) sin( \theta) r^2 d\phi d\theta
and I'm thinking that r' is just r so then it would be
p = \int_0^{2\pi} d\phi \int_0^{\pi} r'^3cose(\theta)sin(\theta)d\theta
The obvious problem that then comes up is that then appears is that I get a 0 term from the second integral that makes my whole monopole moment zero. Is this correct?
if you are supposed to calculate the monopole moment then you integrate the charge density only. the formulas you have above are those for a dipole moment. monopole moment is just total charge
The monopole moment is zero. Some of your formulas are wrong, as Capt. pointed out.
Ok, thanks! I think I see what I did wrong!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
