What Is the Second Force Acting on a Mass in the x-y Plane?
  • Thread starter Thread starter dflutedevil
    Forces
The discussion focuses on calculating the second force acting on a 1.5 kg mass in the x-y plane, which accelerates at 7.3 m/s² at an angle of 30 degrees from the x-axis. Given that one force has a magnitude of 6.8 N directed along the +x axis, the net force can be determined using vector addition. The required second force can be calculated by applying trigonometric principles to find its components based on the resultant force derived from the mass and acceleration.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of vector addition
  • Familiarity with trigonometric functions and right triangles
  • Ability to resolve forces into components
  • Study vector addition and resolution of forces
  • Learn about Newton's Second Law and its applications
  • Explore trigonometric identities and their use in physics
  • Practice problems involving forces in two dimensions
This discussion is beneficial for physics students, educators, and anyone interested in understanding force dynamics in two-dimensional motion.
dflutedevil
Two forces, both in the x-y plane, act on a 1.5 kg mass that accelerates at 7.3 m/s^2 in a direction 30 degrees counterclockwise from the x axis. One force has magnitude 6.8 N and points in the + x direction. Find the other force. Express it as a comma separated pair of components.
I know this seems easy but I'm just not getting it. Any help?
You know mass and acceleration so you can find the resultant net force's magnitude
You know one component of the resultant force is just a vector of magnitude 6.8N at 0 degrees(on the x-axis)
So that vector + another vector you need to find = the resultant vector
You should know equations for deducing both the magnitude and angle of the second vector(they involve trig and right triangles), then you can use trig to get those components.
if it involves trig then of course it involves right angles
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 25 ·
