How Many Turns of Wire Does the Coil Have?
  • Thread starter Thread starter feedmeister
    Coil Wire
The discussion revolves around calculating the number of turns of wire in a coil connected to a bar magnet and a compass. The user initially attempted to find the number of turns using a formula that included the Earth's magnetic field and the magnetic field of the bar magnet but arrived at an incorrect answer. After further consideration, they realized the correct approach is to use the ratio of the magnetic field of the bar magnet to that of the coil. The user successfully determined the correct formula to use for their calculations. The conversation highlights the importance of accurately applying physics equations in problem-solving.
feedmeister
A bar magnet with magnetic dipole moment 0.51 A m^2 lies on the negative x-axis, as shown in the diagram. A compass is located at the origin. Magnetic North is in the negative z direction. Between the bar magnet and the compass is a coil of wire of radius 1.5 cm, connected to batteries not shown in the picture. The distance from the center of the coil to the center of the compass is 9.2 cm. The distance from the center of the bar magnet to the center of the compass is 22.5 cm. A steady current of 0.632 amperes runs through the coil. Conventional current runs clockwise in the coil when viewed from the location of the compass.
How many turns of wire are in the coil?
B_{loop} = \mu_{0}2\pi R^{2}I/{4\pi}(z^{2}+R^{2})^{3/2}
B_{magnet} = \mu_{0}2\mu/4\pi r^{3}
B_{earth}= 2 E-5 Tesla
\mu_{0}/4\pi = 10^{-7}
I = 0.632 A
\mu = 0.51 A m^{2}
I have been trying to do # of turns = (B_{earth} - B_{magnet}) / B_{coil}
and got 100.1271 but it's not the right answer. Can anyone help with what I'm doing wrong?
Attached is a diagram of the problem.
Thanks and regards,
Yeah I figured it out. It's actually just Bmagnet/Bcoil.
Thanks,
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
